Page 27 of 91 FirstFirst ... 1725262728293777 ... LastLast
Results 261 to 270 of 904
  1. #261
    461 Post(s)
    Holy moly Markie looks smick as too good to use lol . Sticker on top is upside down but. .
    Yeah I know but thats where the hole was drilled in the hat, so I just flipped the sticker to suit. Gotta find these bloody screws too. I think I will also change the top hat bolts to stainless steel and also the mounting bolts.
    Where do I go to get the leads made for the motor to solenoid? Auto elec? I don't have the tools to make these.
  2. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (21st April 2020), Rossco (21st April 2020)
    472 Post(s)
    Industrial Sparkies are essentially busy these days I hear Mark mate but maybe after hours solo shed time casholly and Australia Post delivery might slow one we know down ;-)
    mudski (21st April 2020)
  6. #263
    461 Post(s)
    Yeah I will get this fitted up first then worry about wiring it in. Plus I want to wire in dash switches too. And I have a remote kit aswell I'd like to wire in, if I can.
  7. #264
    201 Post(s)
    Yeah an industrial sparkie or some auto elecs will be able to do it pretty quick, just finding one with the time at the moment will be your real struggle.
    I did see somewhere for sale some premade copper bars rather than cable which would be awesome.
  8. #265
    472 Post(s)
    Sounds great mate, watch them remote kits though, nearly crushed ourselves with a chinese version on a work logging trailer a while ago. Went straight afterwards to the Warn remote (horribly priced) but had zero scary lag like the other death trap design!!
  9. #266
    North brissy
    Be careful putting stainless anywhere load is required. Off the shelf stuff does not have the same rating as a grade 8 tensile bolt.
    Do you guys have cooldrive near by?? These guys can sell you pre-made lengths of your requested cable or make them to your custom length. Other mobs similar to them should also be able to supply.
  10. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    MB (21st April 2020), PeeBee (21st April 2020)
  11. #267
    193 Post(s)
    Mark, I have one of those hydraulic crimp set-ups you are welcome to borrow if you go down the path or making your own leads. Handles a wide range of cable sizes. Slow and steady, bit of shrink tube and happy days.
  12. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    mudski (21st April 2020), Rossco (21st April 2020)
  13. #268
    193 Post(s)
    Good point about the Stainless. Also, put a bit of never-seize of equivalent on the thread, not Loctite. SS is tough but more plastic and will readily deform and bind up in even dissimilar metal combo's. Just bought some M30 threaded bar for work - high tensile grade of 316SS - $1500/m M30 - poison but application specific.
  14. #269
    North brissy
    Yep. Got a quote not long ago for some rated stainless socket head cap screws for an underwater pump. They were m20x60 and were just over $80 each.
  15. The Following User Says Thank You to nissannewby For This Useful Post:
  16. #270
    461 Post(s)
    Thanks Phil I may take you up on that offer. Not sure how to use them but I’m sure I’ll learn.
    Almost time to remove the bar and get the grinder out.
    I’ve been toying with the idea of cutting the loops off the ARB bar and just having the steel bumper section. I kinda like the look of that but I do realise the usefulness and added protection the loops give.
    Thoughts?
