5th May 2017, 04:14 PM
#7571
Finished the frame for the camper annexe to car so won't need to carry shit loads of poles , tested it out and it works well enough for me but will only be used if it's raining .
The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
MB (6th May 2017), PeeBee (5th May 2017)
5th May 2017 04:14 PM
5th May 2017, 06:01 PM
#7572
GQtdauto
Whats the configuration - does the frame stay there or slide out ?
5th May 2017, 06:48 PM
#7573
PeeBee
Frame folds down as in photo but is bolted onto the roof rack , it is held by a grip belt and heavy duty occy strap .
Once these are off the two arms pivot up and I put the spigot piece I made up in either end and pull down .
The brace has holes each end and is just a gal adjustable pole with a hole each end .
One end goes in the hook under the spigot the other end attaches to an eye fixed onto the solar panel holding frame , I just put a big screwdriver though this then adjust the tension I need to pull the canvas tight , may put a occy over the spigot to hold canvas if windy .
I've worked out that GQ needs to be between 2.300 - 2.400 metres from camper side , but ideal is 2.300 ish , it's not that hard to do I have done a few trials and got it every time once I knew what distance works best .
If you want I can take some better photos of the bolted ends and brace connection points .
5th May 2017, 08:02 PM
#7574
GQtdauto
I am still struggling with this ! Maybe when you have it rigged up take a photo for me pls so I can appreciate your design. thanks
5th May 2017, 08:03 PM
#7575
Just ripped out a vacuum solenoid cluster bracket. Wasn't doing anything any more and was taking up valuable under bonnet real estate .
The Following 2 Users Say Thank You to Hodge For This Useful Post:
BigRAWesty (6th May 2017), MB (6th May 2017)
5th May 2017, 08:22 PM
#7576
PeeBee
Have some photos of when I first hooked it up and when I moved the GQ a bit further away they are not great but might be what you're after .
Didn't take a photo from the other side unfortunately, but the next photo I get will be while we are away for 8 weeks although hoping the weather stays fine .
6th May 2017, 06:57 AM
#7577
Full length flat rack for our trip.
Uses rhino rack feet, 6 off.
5 cross bars 300mm apart and 4mm mesh.
It is now black.
Best bit. Cost nothung. All steel lying around from other jobs..
The Following 4 Users Say Thank You to BigRAWesty For This Useful Post:
GQtdauto (6th May 2017), gubigfish (6th May 2017), MB (6th May 2017), Touses (6th May 2017)
6th May 2017, 09:14 AM
#7578
bigguwesty
It is now black.
That's one clean shed mate .
The Following User Says Thank You to GQtdauto For This Useful Post:
6th May 2017, 09:17 AM
#7579
GQtdauto
Bahaha.
Yea sure lol..
Imo a bigger shed youll just have more shoit lol..
6th May 2017, 09:26 AM
#7580
bigguwesty
Bahaha.
Yea sure lol..
I see we have similar storage and filing systems but it looks like you could eat off your floor , mine was clean and tidyish about 3 months ago .
