Page 1093 of 1450 FirstFirst ... 935939931043108310911092109310941095110311431193 ... LastLast
Results 10,921 to 10,930 of 14491
  1. #10921
    22 Post(s)
    The transmission lines are protected above ground except for the section that has been damaged. This section is a flexible link cable (1m length) that allow for free movement as the array frames track the sun (full east to west). Will replace cabling and run it through a length of thick walled flexible tubing and hook it up higher and hopefully out of easy reach.
    It should be steel flexicon or adaptaflex, and done by a qualified sparky.
    96 GQ coil/Cab
    08 G6eT
  2. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    Bidja (21st January 2018), Winnie (21st January 2018)
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Thanks for info mate.
    The current install was done by an accredited installer (back in 2009), guess the quality control demonstrated in the installation could be representative as to why they are no longer in business. Have been stand alone since 1991 and back then there was only a small handful of suppliers/installers in country. I am grateful that all underground work and pump installation wiring was done near 30 yrs ago at a much higher standard of workmanship (remains fully serviceable).
  5. #10923
    472 Post(s)
    What has made you Angry Today???????
    FWIW, ‘The Weekly Times’ I believe years ago had a column of old school detterents for say Crop farmers. Beaten up egg mix with fairy dust sized steel swarf painted on educated the locals apparently without harming the harvest edges or the locals.
  6. #10924
    22 Post(s)
    That's the issue with alot of dedicated solar mobs. They wouldnt know Trade Practice if it smacked them in the face. I see it regularly, same goes for NBN installers and Foxtel installers..
    96 GQ coil/Cab
    08 G6eT
  7. #10925
    That's the issue with alot of dedicated solar mobs. They wouldnt know Trade Practice if it smacked them in the face. I see it regular, same goes for NBN installers
    ... add Foxtel Installers to that list as well
  8. #10926
    22 Post(s)
    Done......
    96 GQ coil/Cab
    08 G6eT
  9. #10927
    Jul 2017
    37 Post(s)
    Yeh and a lot employ mainly sales persons $$$$ (short term and then gone). Catcha
  10. #10928
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    My mother inlaw
  11. #10929
    Legendary dom14's Avatar
    38 Post(s)
    The stinking heat. Got close to forty degree and it's fun having to wear clothes while MIG welding.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  12. #10930
    38 Post(s)
    Quote Originally Posted by Yeti's Beast View Post
    My mother inlaw
    That is quite normal. It's meant to be.
    Cheetah Outreach
