Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 54
Thread: Need new start battery for GU - are the Optima yellow tops still worth it ?
  1. #31
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Sexiest noise ever John Mate!
    An OEM Nissan starter motor throwing a diesel cog into lightspeed life
    Double down on a second D31A weapon paralleled and hold on, your beast will walk itself uphill without an injector pump
    Mine won’t walk itself anywhere.. it’s an auto
    John
  2. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    MB (30th March 2021), Rossco (30th March 2021)
    Morayfield, QLD
    These 6061 billet terminals are well made and really solve any height issues that stacked connectors might cause.
    They fit well with the Optima D31A posts in the middle.
    John
  5. The Following 8 Users Say Thank You to jff45 For This Useful Post:
    MB (31st March 2021), moo73 (12th March 2022), MudRunnerTD (31st March 2021), mudski (31st March 2021), pearcey (31st March 2021), PeeBee (31st March 2021), RickGQ (31st March 2021), Touses (31st March 2021)
  6. #33
    461 Post(s)
    Thanks John.
    Just ordered a pair.
  7. #34
    Ghee that is Pretty!!!
  8. #35
    I also take the second to write the fitting date on the Battery for future reference. If anything goes wrong you will know when it went in and work backwards from there. Note my pic above shows a date in 2018 for last fitment.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Rossco (10th April 2021)
  10. #36
    Morayfield, QLD
    They stamped the date on the negative post. In the pic you can see a C 1 stamped there for March 2021. I also keep the invoice filed anyway because there’ll be no claim without it.
    John
  11. The Following User Says Thank You to jff45 For This Useful Post:
  12. #37
    Yeah i did see the C1 and wondered what that was.
    I have a Battery guy that i have spent a small fortune with and he knows me by sight and has all my purchases on file so no receipt is needed. I like that Stamp though but the Black texta works OK too lol. Enjoy the big cranka mate.
  13. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    jff45 (31st March 2021)
  14. #38
    Expert Mickhead's Avatar
    Oct 2019
    Optimas were good until they were made in mexico instead of the us of a. Try a Lithium starting battery instead.
  15. #39
    Morayfield, QLD
    Finally have it running after having to modify the winch relay bracket. I’d been wanting to do it for ages.
    Also took the opportunity to modify the start relay. The GU sends the power direct to the starter solenoid from the ignition barrel so I’ve added a relay to switch the power from the battery instead. Now the ignition barrel start wire only powers the relay.
    Had to also make a new bracket to hold it down.
    Glad I bought these battery terminals..
    John
  16. The Following User Says Thank You to jff45 For This Useful Post:
    MB (3rd April 2021)
  17. #40
    472 Post(s)
    Magnificent John Mate!!!!
    A truly Beautiful Installation as always, you got some tidy Skills Bloke
  18. The Following User Says Thank You to MB For This Useful Post:
    jff45 (3rd April 2021)
