Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
Thread: GUII heater core replacement
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I’m looking at starting on this in the next couple of weeks. It’s been bypassed for the last 2 years but we plan on taking the caravan south into cooler weather in August so will probably need it.
    I’m aware it’s the whole dash out which doesn’t bother me. I also know there’ll be lots of wiring to tidy up after all the stuff I’ve added over the last 14 years.
    I’ve been trying to get some info on which GUs have the heater core with the tap in the plastic pipe. I think mine might be like that judging by info on Patrolapart.
    Have also read that the thicker later model will fit with some slight modification to the heater box.
    Has anyone replaced the model with tap and fitted the normal pipes? Problem will probably be finding the pipes without paying drug money for whole genuine core.
    John
    461 Post(s)
    I did my GUII a while back. A bitch of a job to do. Wasn't hard just a lot to remove and refit. My GU is a 8/2001 and is uses the cheaper unit that PaP sell. Put your VIN into here : https://partsouq.com/ and this will tell you what core you have.
    Hodge (7th June 2021)
    Morayfield, QLD
    Cheers Mark, I did the Partsouq search last night to confirm it's the heater core with the tap. I'll wait till I have it out to see where it's leaking before I decide what to do.
    John
  6. The Following User Says Thank You to jff45 For This Useful Post:
  7. #4
    461 Post(s)
    Is it leaking in the cab? Is yours a Ti? I’m trying to think why the cores would actually be different. Plus I honestly thought all GU Patrol ran heater cores without a tap. Having a tap would be great for summer as mine, even with all new foam sealy bits on all the diversion flaps, I get hot air coming out of the vents when it’s set to cold and the fan/ AC off. I wonder if shutting the hot water flow off to the heater core would help.
    I actually thought of installing a VT Commodore heater tap in mine and some how using a servo motor to shut the water off. The VT taps don’t just shut the water off but divert the water back into the cooling system so there is no dead flow I. The cooling system.
    geoffayres (9th June 2021)
  9. #5
    175 Post(s)
    Hairy job it is. Hope I never have to trek that trail my self. .
    Have heard of mechanics refusing the job. That's saying something.
    Morayfield, QLD
    Sorry for the belated response, I was taken out of action for a week.
    Mine started leaking into the cabin during our return from Lorella Springs in 2019. I just pulled over and did a bypass at the thermostat housing that's still there today.
    Yes, mines the Ti and, until I started to look at fixing it, I also believed GUs had no tap. It appears to be the early GUs and I'll try to research if the tap is the only difference and if it can be removed because I plan to replace it with the later model pipe if possible. I don't like the idea of putting the 20 year old tap back in and the new cores with tap (at $800) can't possibly be recent manufacture so still risky in my view.
    Where do they typically leak from?
    John
  11. #7
    Morayfield, QLD
    They probably want to avoid the inevitable DIY wiring nightmares that lie peacefully in their tangled mess just out of sight..
    John
  12. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    Hodge (14th June 2021), MB (14th June 2021)
  13. #8
    175 Post(s)
    So true. Mechanic's worst nightmare.
    Opening a owner-wired coloured spaghetti home ellecky can of worms job !
    Morayfield, QLD
    On top of that, everything that goes wrong with the car afterwards will be because the mechanic took the dash out..
    John
  15. #10
    Morayfield, QLD
    There’s a guy selling a heater unit not far from me that has the tap version core. I’ve offered him $50 so I can have something to study beforehand. Should hopefully be able to see if the tap can be removed and have it functioning like the later models.
    John
