Page 55 of 105 FirstFirst ... 545535455565765 ... LastLast
Results 541 to 550 of 1047
  1. #541
    ? Snip What tooth design is used for slabbing?
    Round tooth design mate but only on an 11° angle
    Interesting. On a saw blade a straight cut tooth (chisel tooth) is for ripping along the grain. The angle cut tooth is designed to slice the grain and cut. Effective cross cut. A straight chisel cut blade doesn't slice the grain in front of the cut.
    So the straight cut blade cuts faster on a chainsaw? What tooth design is used for slabbing?
    This is what is meant by square grind. Clearly cannot be achieved with a round file and takes far more skill, you take a triangle shaped file and go from outside the tooth in.
  4. The Following 4 Users Say Thank You to Winnie For This Useful Post:
    Maxhead (23rd October 2020), MB (25th October 2020), MudRunnerTD (23rd October 2020), PeeBee (23rd October 2020)
  5. #543
    330 Post(s)
    Thanks winnie, that is not what I pictured in my head at all.
  7. #544
    194 Post(s)
    OK, new Cigweld 185 arrived this morning - Sunday delivery - Aust post must be really overloaded. Anyway, unpacked it, then down to Total tools for wire and gas, quick read of the manual and guide for parameters and what a difference to the little Rossi. This is just like it should be, really happy. the gas bootle cost was a bit of a slug though, but I now own the bottle (E size, $475 - ouch), but wire was on special.
    The first pic of welds is with the new welder, the second is the best i could get out of the Rossi, both with gas.
  8. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    10G (4th November 2020), jay see (1st November 2020), MB (2nd November 2020), Mickhead (4th November 2020)
  9. #545
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    First welding job should be a trolley seeing as how it looks like it could easily fall off that wheelie bin
    John
  10. The Following 5 Users Say Thank You to jff45 For This Useful Post:
    jay see (2nd November 2020), MB (2nd November 2020), PeeBee (2nd November 2020), Rossco (2nd November 2020), Touses (2nd November 2020)
  11. #546
    194 Post(s)
    I think I can save my time and effort by spending $90 on a 'bought one' I reckon. The welder is quite firmly mounted to the bin with 6 tek screws - learnt about their use from old @MudRunnerTD. Only hassle now is removing them weekly for garbage collection.
  12. The Following 5 Users Say Thank You to PeeBee For This Useful Post:
    10G (4th November 2020), jff45 (2nd November 2020), Mickhead (4th November 2020), MudRunnerTD (2nd November 2020), Rossco (2nd November 2020)
  13. #547
    193 Post(s)
    Just watch out for the main wiring loom in the bin, could cause a world of dramas. . .
  14. The Following User Says Thank You to Rossco For This Useful Post:
  15. #548
    330 Post(s)
    Dont talk about his GQ like that Rossco! PeeBee has done a lot of work to transform the Tardis into something to behold. Bhahahahaha!!
  16. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
  17. #549
    194 Post(s)
    Way back in 1997 we were camped at jacks waterhole in the Kimberley next to a guy from Sydney with a brand new landcruiser and a brand new jayco. He recounted the story about his fuse blowing hassles with the jayco from pick-up. Could not keep the main breaker from tripping on his way from Syd to Alice, so at some time along the road he pulled the breaker out and jammed a 1/4" bolt into the jaws, which fixed it for a while then something else 'big blew' and he lost all power. Getting to Alice he found a service agent and the van was booked in. They eventually found a large tek screw right thru the middle of a major cable. Lucky it didn't all go up in smoke, but he was 'oh so proud' of his electrical mastery - as I am at times!!!
  18. The Following User Says Thank You to PeeBee For This Useful Post:
  19. #550
    80 Post(s)
    How much for a gas refill, @PeeBee?
