11th March 2017, 08:43 AM
#3501
Cant see any time when a Gennie would be required at camp, with all the solar
and LED technology out there there is no point,
My first camp light was an indicator globe with a reflector made from a beer can,
after that I used 12v down lights, this was well over 20 yrs ago.
Sound travels at night so no matter how quiet you think it is ,,,it will annoy some one
11th March 2017 08:43 AM
11th March 2017, 09:39 AM
#3502
Travelling Podologist
I also have a little Honda Eu10i. Bought it as an impulse buy when travelling, carried all round Australia & only used it to keep the crank battery charged for a couple of weeks when the alternator died. It is probably the quietest gennie out there, but even so, in the quiet of the bush it is noticeable. When camped near others I always approached neighbours to explain I would need to run it for a while, no-one ever objected but were generally appreciative of the approach & understanding of our dilemma. Whenever we turned it off it the quiet just came flooding back! It was useful until we got a replacement alternator, but we’ve never taken it away camping since. Solar + dc to dc charging gives us all the power we need to run two fridges plus various other bits & pieces indefinitely.
Carrying a gennie is a reasonable solution for some, & bearable by those who are their camping neighbours if used with consideration. Running it at night just to power a 240v light globe is not reasonable! Running it during the day to top up a battery is far more acceptable. Note however that the 12v output that most gennies have are inadequate for battery charging, generally the voltage is insuffient to charge a battery & that is not what it is intended for. For battery charging with a gennie a 240v mains charger is generally needed.
Regarding noise, an increase in decibels does not equate to a linear increase in noise. The 67 to 72 decibels of that Ryobi gennie is not just a little louder than the likes of a Honda EU10i (52 dB), it’s a *lot* louder. The level of noise doubles for every 3 db increase! (There is more to it than that though - if interested see http://www.noisehelp.com/decibel-scale.html). This video gives a comparison between the dB of several generators - I sure wouldn’t want to be camped next to a 72dB one on full load!
14th March 2017, 02:56 PM
#3503
brought a spare paper air filter to use when I remove my K&N for cleaning.
Ive stayed at camps when ppl have dug a hole placed their
genset in the hole and covered with a piece of Corrigated iron.
YOU CAN STILL HEAR THEM NO MATTER WHAT YOU DO.
Should be banned from 1600hrs on to say 0800hrs fair for all
not just the greedy ppl
14th March 2017, 04:02 PM
#3504
Mostly agree with the comments about Generators and whilst I have a 2KVA Gennie I have not used it Camping.
If I was on a extended trip I might take it for a Back up.
What really annoys me is Doof Doof Music in the middle of the Night whilst Camping in the Bush.
Take your bloody Ear Plugs so you don't annoy anyone else.
Yes I am a Cranky old Bastard LMAO
The Following 2 Users Say Thank You to Bob For This Useful Post:
GQtdauto (14th March 2017), threedogs (14th March 2017)
14th March 2017, 04:09 PM
#3505
Nothing better than sitting around a fire with some good friends and
Johnny Cash or Kenny Rogers in the back ground.
Not a fan of musical instruments at camp either lol
14th March 2017, 04:16 PM
#3506
threedogs
This works if you fill the hole in before putting the corrigated iron on top.
The Following User Says Thank You to 4bye4 For This Useful Post:
14th March 2017, 04:49 PM
#3507
Patrol Guru
Bob
X 2 ...... and I don't think we are cranky old bastards, just normal old pharts who want to enjoy the serenity.
The Following 2 Users Say Thank You to TimE For This Useful Post:
Bob (14th March 2017), threedogs (14th March 2017)
14th March 2017, 04:54 PM
#3508
Patrol Guru
Bought 1 Kincrome 4000 kg (its lift capacity not weight !) bottle jack from SCA for $55. Discovered on a recent trip where rear tyre was shredded that Nissan jack couldn't lift the axle high enough, needed another jack to get the axle up high enough so Nissan jack could slide under shock mount then lift wheel high enough off ground to fit spare. Was on a nasty bit of track with little room to maneuver and no flat rocks to drive onto!
The Following User Says Thank You to TimE For This Useful Post:
14th March 2017, 05:05 PM
#3509
Cuppa
Carrying a gennie
I want that last one. Should be able to run the sandwich toaster, 60" tele, surround sound, splitties, deep fryer for snacks and full sized coffee machine. . . Actually on second thoughts might need a couple of KV Kubota, now that's camping . . .
Sent from my SM-T800 using Tapatalk
14th March 2017, 07:36 PM
#3510
threedogs
Johnny Cash or Kenny rodgers in the back ground.
Not a fan of musical instruments at camp eitherlol
Geez threedogs I think I'd move closer to the doof doof than listen to country and western !
