Results 11 to 20 of 34
Thread: Stretch is having a fuse blowing
    Patrol Guru
    Jul 2014
    6 Post(s)
    Not sure if it's the same for GU's, but I had a weird issue a while back kinda similar to yours. I believe in the GQ, from what I could find/research etc, that there's a common earth that runs into the dash and controls a lot of these.
    Mine was frayed in the engine bay and caused me some issues like these, I replaced the bad bit of wire and all good since.
    Not sure if it helps, but food for thought.
  2. The Following 2 Users Say Thank You to Throbbinhood For This Useful Post:
    dom14 (23rd February 2017), MEGOMONSTER (23rd February 2017)
    Patrol Guru TimE's Avatar
    Canberra
    I had an occasional fuse "pop" when I had the camper plugged in, seems that at times 10 amp was exceeded (flashers turned on?), auto elec said it was fine to put a 15 amp fuse in (having checked there were no other issues), never had a problem with the trailer attached since.
    Note: I would only up the fuse if confident that the load on the circuit was a "legitimate" load and not another "issue". and that he wiring could take it (as advised by a qualified auto elec).
  5. The Following User Says Thank You to TimE For This Useful Post:
  6. #13
    Patrol Freak gaddy's Avatar
    redlands
    I had a issue with blowing the brake light fuse every so often , after working out what I had added traced it to the barn door table , screw and rubbed on the door brake light wire !
  7. The Following User Says Thank You to gaddy For This Useful Post:
  8. #14
    as suggested check some/all earth straps.
    check under right rear thats where most ppl cut into loom for trailer plug
  10. #15
    Yep, pretty much where my issue was a couple of years back, passenger side rear clusters..... wiring was a mess so to it to an auto sparky to sort out
  11. The Following User Says Thank You to Clunk For This Useful Post:
  12. #16
    originally mine was done with scotch loks but after venting
    they soldered all connection then shrink sleeved them as you should
    Lazy buggers eh
  13. The Following User Says Thank You to threedogs For This Useful Post:
  14. #17
    Western suburbs of Melbourne
    11 Post(s)
    Ha ha. Brain fart time. If all else fails, try changing the bayonet style globes. I have come across some that have shorted out in the base.
    I had that exact problem and was the first thing I said to him.
  15. #18
    11 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    At this stage everything mentioned is worth pursuing, even if it ends up all good.
    The Patrol it self hasn't changed all that much in 20 yrs. lol
  16. #19
    11 Post(s)
    Quote Originally Posted by TimE View Post
    He has put in a 15 amp fuse just to get by but it pop that as well.
    So went back to 10amps.
  17. #20
    11 Post(s)
    Quote Originally Posted by gaddy View Post
    I have a feeling it gonna be something like that.
