5th September 2016, 07:06 PM
#3061
Bought a new car.
The Following 6 Users Say Thank You to firm351 For This Useful Post:
Clunk (6th September 2016), mudski (5th September 2016), Stropp (6th September 2016), threedogs (6th September 2016), Wine_maker (4th December 2016), Woof (5th September 2016)
5th September 2016 07:06 PM
5th September 2016, 07:09 PM
#3062
Sprock
Happy birthday to me !
Attachment 68916Attachment 68917 whilst I didn't technically buy it - the missus organised it - I guess in reality I did pay for it
Your money is her money mate. So no. You didn't pay for it. Lol.
BigRAWesty (15th September 2016)
5th September 2016, 07:10 PM
#3063
firm351
Bought a new car.
When is it going in for a lift, 33's and bar work?
6th September 2016, 12:01 PM
#3064
The 747
Bought a Carter 4600HP electric pump, should be able to install it this weekend to see if it makes much difference with my old worn out mechanical pump.
6th September 2016, 12:26 PM
#3065
Winnie
Run it via relay mate so that it only comes on when you get oil pressure. So then you can still have the ignition on, no motor running, and the pump wont operate. If your motor has the switch and not the sender unit that is. Not sure how to wire it up using the sender. Also run a fuel line by pass too so if the pump dies the pump can still suck the fuel through.
6th September 2016, 12:29 PM
#3066
The 747
I believe with this Carter pump that fuel can flow freely even if the pump has failed.
I will just wire it to ignition, I can't think of a time I have had the car switched to ignition without the engine running anyway.
6th September 2016, 12:44 PM
#3067
Winnie
Is it to late for you to swap to a 4601hp?
Wiring to ignition is fine. Makes services easy for priming the fuel filter prior to starting.
6th September 2016, 12:51 PM
#3068
The 747
Damn, yeah it is.
From what I can tell the only difference between the 4600hp and the 4601hp is the pump pressure?
6th September 2016, 12:54 PM
#3069
Yes it can but being a rotary vane pump there still is a chance of the vanes blocking the fuel path if the pump stops. Also if the pump fails there might be a small loss in top end rev power due to the extra route the fuel needs to take. The by pass was easy to do though...
6th September 2016, 01:14 PM
#3070
mudski
You got your patrol back yet ?????????
