24th March 2021, 06:35 PM
#61
Moderator
MB
Wow! a split second later MB!!!! interesting to view this image and the placement of my back wheel. I must have slid into the little rut i reckon. Shit went pear shaped.
I wonder if i had turned off my rear locker too might have helped here.
Check out my Toy -->
Rogue Dung Beetle
24th March 2021 06:35 PM
24th March 2021, 07:46 PM
#62
Winnie
We might be after a few if we can get them for the right price. Really showed their value when we had to jump in the mud to retrieve Rossco's hook from underneath
The plastic is cheap and the end fittings are just some steal tube and bar. A unit could be made for $50-$100.
The Following User Says Thank You to nissannewby For This Useful Post:
24th March 2021, 07:51 PM
#63
The 747
nissannewby
Yeah wow. The material used is polyurethane, same as what some bushes are made of. I thought it was pretty expensive stuff.
The Following User Says Thank You to Winnie For This Useful Post:
24th March 2021, 08:38 PM
#64
Moderator
nissannewby
Yeah it is not just a plastic and a straight PU. It has a flexibility cross between a rubber and a plastic. I asked the guy i got the DazWing Perspex from, he sold a PU rod the right size but was very rigid. No good. There is a market for the right kit for sure. Mine is 65 or 70mm, the one listed above is 50mm.
Rogue Dung Beetle
24th March 2021, 08:45 PM
#65
It will be a pu with some type of silica content similar to that used in the adult industry. I will do some research and see if I can find a material. It may even have some kind of vinyl in it. PU is pretty flexible though on its own. A lot of can bend around onto itself. Like all things rubber and plastic there are many grades and shore ratings.
The Following 3 Users Say Thank You to nissannewby For This Useful Post:
MB (25th March 2021), MudRunnerTD (24th March 2021), Winnie (24th March 2021)
25th March 2021, 05:24 AM
#66
Tassie 2021 6 Blokes 3 GQs
Pretty sure we’ve bought the exact PU blend for a spring replacement on some indoor playground products before. It was horribly expensive stuff and IIRC something like $100plm for only 25mm diameter rod.
https://www.profileplastics.com.au/
I’ll ask our designer today which PU blend was sourced as it was critical for us also to have instant memory return and zero splitting where the fixing bolts are drilled through.
I just purchased the 4WD Shed 50mm one complete for the 12v Iskra/Mahle High Mount upgrade but will be upgrading it to the next diameter larger size if I ever copy Darren and run 24v through it faster. A wee bit too flexible as it is on the faster 12v winch but would be fine on a low mount winch as only one last winch click currently folds it to half way too easily
The Following 3 Users Say Thank You to MB For This Useful Post:
MudRunnerTD (25th March 2021), nissannewby (25th March 2021), PeeBee (25th March 2021)
25th March 2021, 01:19 PM
#67
The Following 2 Users Say Thank You to MB For This Useful Post:
MudRunnerTD (25th March 2021), Rossco (25th March 2021)
25th March 2021, 04:59 PM
#68
Moderator
MB
Just stopped into Profile Plastics quickly to pick up some acrylic colour samples for a job.
Got a quick quote on the Donkey PU
60mm diameter (90 hardness) = $435 plm Holy Crap Anoly
Yeah crazy expensive. I have looked into it when I was buying. I scored mine 2nd hand from a bloke in Yarraglen for $150. AB went and grabbed it for me. I jumped on it when I saw it for sale on Facebook... way back before it was Trendy
Rogue Dung Beetle
25th March 2021, 05:29 PM
#69
When did trendy start by having a big black dildo hanging off the front of ya car? More like individual perhaps????
The Following 4 Users Say Thank You to PeeBee For This Useful Post:
MB (25th March 2021), Plasnart (25th March 2021), Rossco (25th March 2021), Winnie (25th March 2021)
25th March 2021, 06:20 PM
#70
