Page 797 of 1049 FirstFirst ... 297697747787795796797798799807847897 ... LastLast
Results 7,961 to 7,970 of 10488
  1. #7961
    192 Post(s)
    Hey Nath nah shouldn't light up without a trailer but as soon as you plug it in should be blue. Don't know how but knows when attached to the brakes will light up red when braking then. Took a while to calibrate mine probably half a K of on off brakes before it knew which way it was going.
  2. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    Bacho86 (16th September 2017), Yeti's Beast (17th September 2017)
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Awesome thanks for the confirmation, hopefully picking up the camper in the next couple days so will be able to try it out!
  5. The Following 2 Users Say Thank You to Bacho86 For This Useful Post:
    Rossco (17th September 2017), Yeti's Beast (17th September 2017)
  6. #7963
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    When you first connect the camper the LED might flash various colors for a while, but that's just the unit calibrating. Once it's settled it will remain blue while connected as Rosco said.
  7. The Following 2 Users Say Thank You to Yeti's Beast For This Useful Post:
    Bacho86 (17th September 2017), Rossco (17th September 2017)
  8. #7964
    49 Post(s)
    Someting that I have to get done and I'll gladly pay for someone else to do.
    Rear main seal.
    Any ideas on price $200-300 or am I way off??
  9. #7965
    462 Post(s)
    Rear main seal.
    Way off dude. Seal is Under $100, its a days job so Im guessing around $600 minimum.
  10. #7966
    49 Post(s)
    A days job????
    At home yeah, but in a shop on a hoist and with all the right tools 1/2 day Max. It's box out and back in. What do they charge to fit a clutch wouldn't be much different in the process would it?
    What's labour rate
    $80 p/h x 4 hours $360 + $100 seal = $460 and if you add gst call it 500.
    Yeah your pretty close Mark.
  11. #7967
    462 Post(s)
    A days job????
    What's labour rate
    Yeah a clutch is a days job. Same time for this and a rear main. Eric might remember what he was charged for a clutch r & r. @Hodge.
    jay see (17th September 2017)
  13. #7968
    49 Post(s)
    D!ckhead I am.
    Should have got it changed when I got the reduction gears put in. It was wet but never dropped oil.
  14. #7969
    Mar 2011
    14 Post(s)
    What did you do to your Patrol today!
    Rear main seal.
    Unfortunately mate that's going to be an expensive one, mine was almost $1000 - and that was shopping around!
    As Mudski said the part itself is less than $100, but it's the labour cost / time that kills you
    And what 4wd mechanic are you going to that only charges $80 for labour?? Lol
  15. The Following User Says Thank You to Bacho86 For This Useful Post:
  16. #7970
    175 Post(s)
    A days job????
    What's labour rate
    Clutch replacement was around $650 labour. Majority of labour being the gearbox on / off.
    I don't know how much more of labour there is for a rear main seal for your motor mate...
    I asked about doing my rear main seal while my gear box was off for this, even though it wasn't leaking I thought about being pro-active.
    But, On my motor i've been told it could be a hefty job. Something to do with peeling off the gasket from underneath the sump as that has to come off too sometimes. So doing the rear main seal could be opening up a can of worms. So I opted for NOT getting it done...
    I don't know about your motor John, could be simple?
  17. The Following User Says Thank You to Hodge For This Useful Post:
