23rd September 2017, 03:31 PM
the evil twin
Yep, totally agree, a locked TC reduces tranny temps by heaps and yes the Tranny ECU only locks the TC in Overdrive.
After the mod the ability to lock the TC in 3rd or D and also prevent the Lock Up cycling in OD when rolling on and off the throttle when towing is one of the best things to do for the Tranny IMHO.
I noticed a worthwhile change in fuel economy (mine was a dual fueller) of an extra 50 K's or so on LPG but it would depend on terrain etc an WA tends to be open and flat.
The big difference was the much lower tranny temps when towing my Camper on its generally 1500 to 3000 K round trips
I only know the series l GU auto as that is what I have and the Maverick was a manual. But the GU locks the TC in 2nd, 3rd(D) and OD. An improvement from the GQ I guess.
98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
"GO YOU CROWS"
The Following User Says Thank You to Chubba For This Useful Post:
GQtdauto (23rd September 2017)
23rd September 2017 03:31 PM
23rd September 2017, 04:20 PM
No idea what's in our 2002 GU either Chubba but I do know it only locks in OD same as the GQ .
If I was keeping the GQ I would go for a wholesale auto nomad valve body and have the whole box upgraded because I believe you can even get them to lock in first gear .
The Following User Says Thank You to GQtdauto For This Useful Post:
Chubba (23rd September 2017)
23rd September 2017, 05:29 PM
I am he, fear me
Chubba
Yep, GQ Autos in the factory configuration only lock the TC in O'drive above 80 KPH which is why the mod is so popular with them esp if running 33's.
So GU is different then?
Must admit I have never driven a 4.5 tho so don't know that much about them.
Those and the 2.8TD are the only two variants of MQ, GQ, GU I haven't had as either a private or fleet vehicle over the years.
23rd September 2017, 05:54 PM
I don't know but GQtdauto said his 2002 GU only locks in OD. Mine is a Ti. So maybe something to do with that.
"GO YOU CROWS"
23rd September 2017, 07:03 PM
Chubba
I'm sure I read somewhere that the earlier GU and 94 < were the same box basically just slightly different wiring or tcu .
Towed the same camper in both nissans and bugger all difference in the way the box works or engine heats up when the going gets tough , having just put the temp gauge on the tranny back in May for the Birdsville trip I'm still amazed at how high temps can get when the converter isn't locked .
