18th November 2018, 08:04 PM
#8731
Winnie
Interesting as Patrolapart recommended me to use silicone instead of a gasket for the water pump, it gets the fins closer to the timing case and helps with flow and cavitation apparently.
Geez the difference would be less than quater a millimetre Chris. Considering the Gasket is a bee's dick over that. I doubt that would make a difference. But who knows for sure.
18th November 2018 08:04 PM
18th November 2018, 08:07 PM
#8732
mudski
I agree. The gasket is a designated spacer of known thickness, where the silicone is anyones guess and if too thin may not seal for long anyway.
mudski (18th November 2018)
18th November 2018, 08:10 PM
#8733
Silicone/Silastic would better seal pitting I would imagine?
19th November 2018, 10:29 AM
#8734
MB
Can see the point, however the gasket is a surface seal, clamped with uniform pressure - or it should be if the thing is torqued correctly, so in theory, the pitting would be covered unless it goes to the edges of the hole and you have a channel from inside to outside, then a liquid seal would be better. Solid gaskets are not designed to deform as such, more cater for surface roughness values at best - I know sounds contradictory, but they will deform on a smallish level, not fill up depressions.
19th November 2018, 10:50 AM
#8735
Replaced the filter in my ProVent catch can. Old one looked OK for 80,000klms, the recommended replacement frequency.
19th November 2018, 01:25 PM
#8736
Had a spazmotic idle when cold, ranging up to 770rpm.
Disconnected the start battery and sprayed tho MAF.
All seems to be OK now, happy with the outcome
GQtdauto (19th November 2018)
19th November 2018, 07:37 PM
#8737
bazzaboy
I swap mine out at every 5k service and wash the old one ready for the next change. They obviously last longer than 5k but I just made it part of my service so I dont forget about it.
21st November 2018, 11:33 AM
#8738
It broke down for the first time on the weekend since its conversion.
10,000 kay in on some hardcore trips including , snow, west tassie, high country and some hard core day trips...
I dont know what it is but will get to it eventually
https://youtu.be/NA1yj32XRvc
The Following 9 Users Say Thank You to Baby Daddy For This Useful Post:
AB (21st November 2018), Bidja (21st November 2018), gaddy (21st November 2018), MB (21st November 2018), mudnut (21st November 2018), PeeBee (21st November 2018), rusty_nail (21st November 2018), Touses (21st November 2018), Winnie (21st November 2018)
21st November 2018, 06:24 PM
#8739
Administrator
Baby Daddy
Bugger mate, that wouldv'e been a pricey recovery but what a beast of a recovery vehicle!
GQtdauto (21st November 2018)
21st November 2018, 06:27 PM
#8740
I saw that vehicle drag a land rover out of the Caledonia River via Dingo Hill, did it like a walk in the park, amazing machines
