Results 1 to 10 of 10
Thread: Can a 4 inch lift be put down to a 3 inch lift ?
    Expert First Pooy's Avatar
    Mar 2018
    Can you lower a 4 inch to a 3 inch what will it take can you just put 3 inch springs in and adjust the panhards ?
    22 Post(s)
    Yeah that'll be fine it's just like sagging springs
    96 GQ coil/Cab
    08 G6eT
    Mar 2018
    I want a 4 inch lift and I was thinking if I got done and needed to go back to a legal 3 inch lift I would do that
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Pretty sure 50mm is highest legal without engineering, but I could be mistaken.
    Mar 2018
    New rules you are now allowed a 3 inch lift engineered
    22 Post(s)
    Why don't you keep it at 3 inch lift, cut the guards and run 37's for play tyres. Chassis height will be pretty much the same as 4in lift 35's, but with extra diff clearance
    96 GQ coil/Cab
    08 G6eT
    461 Post(s)
    Quote Originally Posted by First Pooy View Post
    Got a link to these new rules?
    Mar 2018
    I don't know how to link but here is a screen capture of it
  10. #9
    Jan 2017
    South Australia
    11 Post(s)
    So the documents attached to that say you still need certification with suspension lift over 50mm.. from an "approved person"
  11. #10
    Mar 2018
    So yes you can have a 3 inch engineered legal lift were as before you were limited to a 2 inch suspension lift
