Page 961 of 1049 FirstFirst ... 4618619119519599609619629639711011 ... LastLast
Results 9,601 to 9,610 of 10486
  1. #9601
    I sealed off the air inlet to the carby, and poured a bucket of water into the snorkel to check it out. I was surprised how may leaks showed up.
    The main concern is the pre-heat air flap, which produced a steady stream of water. The next worse leaks were at the dust spinner and the factory flange to the mud guard.
    I still haven't worked out a way to seal the pre-heat and also keep the vehicle road worthy, and it needs the heat to run properly in winter. I did try a brass reducer and removable plug, but it restricted the air flow too much.
    I am toying with the idea of running a flexible steel steel pipe in parallel from the spinner outlet across the headers and up to the pre-heat .
  2. The Following User Says Thank You to mudnut For This Useful Post:
    10G (31st August 2020)
    Nov 2010
    Getting a life...
    38 Post(s)
    Ripped off the old tint, ready for new. Shoulda done it years ago. Sprayed all the window switches, and changed the oil. Gotta love having 5 days off between Changing jobs.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  5. The Following 5 Users Say Thank You to katwoman For This Useful Post:
    10G (1st September 2020), MB (1st September 2020), Mickhead (13th September 2020), mudnut (31st August 2020), Plasnart (31st August 2020)
  6. #9603
    Scrubbed the above idea and just made a rubber bung with a small bolt through the centre with a wing nut to squash it and lock it in place. Just gotta remember to fit it and block the pre-heat vacuum line before heading out bush and to remove it when getting home. Too easy!
  7. The Following 2 Users Say Thank You to mudnut For This Useful Post:
  8. #9604
    109 Post(s)
    Oi Kat woman, where you been? Get back on here! Glad you're looking after the trol but haven't heard from you since Sir Roofy's.
  9. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    katwoman (1st September 2020), MB (5th September 2020)
  10. #9605
    Nov 2010
    Getting a life...
    38 Post(s)
    You can have too much of a good thing . Nah, just, you know , living the dream and all.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  11. The Following 3 Users Say Thank You to katwoman For This Useful Post:
    MB (5th September 2020), mudski (1st September 2020), Plasnart (1st September 2020)
  12. #9606
    @katwoman wow and hi great to hear from you.
    My tint is darkest legal for the front windows.
    Limo tint for the cargo area and rear doors
    Ive had the tint now for over 10 years and I think its to bright
  13. The Following 3 Users Say Thank You to threedogs For This Useful Post:
    10G (6th September 2020), katwoman (1st September 2020), MB (5th September 2020)
  14. #9607
    Nov 2010
    Getting a life...
    38 Post(s)
    Hey john, it’s been a while. I was thinking real dark for barn doors and back windows, lighter for the doors, if it’s too dark it’s hard to see in the bush, but I love the look of dark tint
    My other cars tints are not legal tho.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  15. The Following 3 Users Say Thank You to katwoman For This Useful Post:
    10G (6th September 2020), MB (5th September 2020), Mickhead (13th September 2020)
  16. #9608
    49 Post(s)
    Ordered stuff.
    Finally got around to ordering the winch rope, hook and hawse.
  17. The Following 2 Users Say Thank You to jay see For This Useful Post:
  18. #9609
    472 Post(s)
    Parked her in the shed as she was trembling at the thought of this recovery load we came across :-)
    Another 4.2L, albeit Perkins with both diffs locked @ 0.5kmph crawling did the trick
    Old mate unfortunately wasn’t helping the “Asian’s Can Drive” cause :-)
  19. The Following 4 Users Say Thank You to MB For This Useful Post:
    10G (6th September 2020), jack (6th September 2020), Mickhead (13th September 2020), Plasnart (5th September 2020)
  20. #9610
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Mad coincidence. I came across the same size and type of truck in the same predicament on the way to my parents yesterday. But it was full of logs, had slid right off the road and was being dragged out with a skidder. Lucky, because I don't think danis civic would have been much help
    Hello from Under Down Under!
  21. The Following 5 Users Say Thank You to taslucas For This Useful Post:
    10G (6th September 2020), AB (6th September 2020), jack (6th September 2020), MB (6th September 2020), rusty_nail (6th September 2020)
