Results 11 to 20 of 21
Thread: Help overheating problem
    194 Post(s)
    Quote Originally Posted by JackCollo View Post
    Fingers crossed indeed
    So which way is the cap supposed to go. To be honest I didn’t know they had a right and wrong way
    I might do a full radiator flush ASAP
    I would say this is only relevant if you have been dicking around with the cap recently. If not then its something else.
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    Yeah I have because I checked the level in the radiator so the cap was removed
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
  4. #13
    194 Post(s)
    @AB, whats the correct orientation of the overflow cap - is there an in and out which suggests a check valve of some description? If this has not chan ged, then pointing toward the radiator cap?
  5. #14
    581 Post(s)
    I'm not sure about zd30's mate but the td42 overflow which surely is similar to that is long side down on inlet side and short side on external.
    Liquid goes in, long side sucks back into radiator, short side exerts coolant if bottle is full.
  6. The Following User Says Thank You to AB For This Useful Post:
    PeeBee (21st November 2017)
  7. #15
    Dec 2016
    I have no idea to be honest
  8. #16
    581 Post(s)
    I'm too lazy to take off brace.
    Long side left, when cool, sucks back into system.
  9. The Following User Says Thank You to AB For This Useful Post:
  10. #17
    Dec 2016
    I’ll take a picture of mine when I get the chance but I really wanna get this sorted out.
    Is it worth pulling the radiator out and power washing it?
  11. #18
    194 Post(s)
    Do the easy stuff first, check as above. The first question needs to be 'what has changed?". Is it simply the weather and the radiator is suffering because the condition is down, hence its getting hotter, or have you done something to change the heat transfer? New set of radiator blocking lights, bug screen over the front of the grill, blocking flow, radiator level simply down and you didn't notice and then it started to run hot? Is the coolant at the end of its life/ This 'hot snap' has hardly been severe. Do you have a collapsed hose?
  12. #19
    Dec 2016
    Yarrabah
    Hey Guys
    I have a ZD30 the orientation for the rad caps is the pressure cap goes on the overflow bottle near the guard
    n the normal cap goes on the radiator . Hope that helps
    Craig
  13. #20
    193 Post(s)
    Hey Jack, make sure the overflow bottle cap is on the right way too @Rossco had exact issue and it was overflow bottle cap was on wrong way so hot coolant goes into overflow bottle and cant come back to radiator so pisses out of overflow.
    Yeah was ready to do a head gasket on the thing. Would have been a bugger to do that and have it do the same thing afterwards. Always love a cheap fix. . .
