Results 21 to 30 of 32
Thread: Inverter question regards arc welder use
    That will only be a start up (surge) rating as some appliances can use up to eight times there running current upon starting. Does it say anywhere that it has a soft starter incorporated in the circuit?
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Bloody hell, upgraded to a pure sine wave to try and overcome these issues with electric tools not liking modified sq wave. i know my grinder , power saw and drill are a lot noisier on Mod Sq wave than the pure sine wave. If this inverter has internal protection it doesnt indicate externally and certainly has not tripped a fuse.
    I just had a close look at the nameplate and here in lies the problem. This thing is sold with a 10amp plug, but the nameplate says it can draw 25amps. What confuses me then is how this operates on a 10amp circuit, or is the 26amp so quick on start up that the fuses in the fuse box cope with the surge?
    So this suggests the inverter size needs to be circa 7kw , but is this a normal load rating of simply the strike power rating (240V x 30A)? This does my head in to be honest. Might just stick with the readywelder2 and be done with it.
    They do make a portable 12 volt mig which is very compact in size but expensive , can be used gas or gas less .
  4. #23
    194 Post(s)
    Yes I have the ReadyWelder2 that runs off 24/36Vdc and gassed or gasless already, looking for a package that is smaller
    GQtdauto (8th August 2017)
  6. #24
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I thought those things were ok and compact in size ? But yes they do hook up to batteries which is what you're trying to avoid .
  7. #25
    194 Post(s)
    I guess I could take it out of the plastic case, maybe just make do - still thinking, very s l o w l y.
  8. #26
    194 Post(s)
    Scant info in 'brochure ' , hardly an operating manual. I have emailed them regards recommended inverter size now that its identified as a problem, waiting to get a reply, maybe??/
  9. #27
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Put a smaller SCA inverter welder on today and yeah you just get a weak spark .
  10. #28
    194 Post(s)
    Initial contact from supplier suggests 6 - 9kva generator - subject to confirmation - so waiting to hear what the actual size is.
  11. #29
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Never tried to run a welder off my gennie 2000 watt peak but I think it would be a waste of time trying .
  12. #30
    194 Post(s)
    From what we have found out recently it isn't going to work.
