Page 986 of 1049 FirstFirst ... 4868869369769849859869879889961036 ... LastLast
Results 9,851 to 9,860 of 10488
  1. #9851
    472 Post(s)
    That agm will be plenty good enough for what you are using it for MB. Don't regret it, it will kick ass!
    Yes my bad Chrisso Mate, only 2 x 26L little Engels in a much cooler climate it will KickAss beyond any setup had before on scrub trucks
    Lithium I reckon read would be insane in the most demanding longer term stays Outback for sure ⭐️⭐️
    109 Post(s)
    It’s not just you Hodgey Mate
    Every stocky TD42T I’ve ever owned also must be broken, I too shit myself pushing ours past 3,000rpm as it’s completely useless power wise beyond I’ve nuffy found
    Years gone by I drove heavy vehicles that had the optimum torque band highlighted in green on the tacho. In the case of the TD42T I'd think it would span from 1500rpm to 2300rpm or thereabouts. Why anybody would flog these to 4k is beyond my courage!
  4. The Following User Says Thank You to Plasnart For This Useful Post:
    MB (4th February 2021)
  5. #9853
    472 Post(s)
    Slightly looong winded findings here tonight but hopefully can help/save some underwater adventurers donks out there too
    Picked up the truly beautifully manufactured ‘Black Mamba-Airbox’ yesterday
    Impeccable welding appears in my slowly failing eyes
    My first and only honest concern found was the choice of using the rubber nipple drain thingy much like on my tractor Donaldson that I wouldn’t dare take fully underwater through the creek.
    Decided to stop by @Rossco ‘s (The Skinny Mountain GQ Bushman’s :-) shed to gauge his well Legendary experienced deep underwater off-road thoughts for my concerns.
    Agreed together that it wasn’t extreme optimal and maybe a manual on/off mechanical simple valve like our other ‘Millweld’ beloved airboxes should be adapted for peace of mind.
    Couldn’t help myself later and decided to get a secondary Legendary opinion/advice from the (Vic-Otways Swamp Nutter) @MudRunnerTD.
    All three of us are now confirmed on the same page concerned for the OEM design and Daz has kindly put forward a simple solution he’s faithfully used before as I have been known to forget shutting off the manual valve on my other airbox drain.
    Here’s a view from the inside as purchased:
    Here’s a view bathtub tested tonight:
    (slowly filled to bathtub water level in under 60 seconds)
    Unfortunately took another approximately 60 seconds to drain out the equalised water level:
    OEM rubber drain removed was a complete disaster obviously within seconds:
    Now for @MudRunnerTD ‘s Legendary advice:
    (test photos below, not finished product:-)
    “Find a larger Sikaflex type nozzle in your shed Mark”
    “Trim the end off larger for drainage assistance”
    “Find an old inner tubey”
    The absolute worst I could get it to intake was the volume of the foldable tube before full kink upwards:
    The drainage is almost as instant as was tested with the hole completely open:
    A brilliant idea thanking you very much DazMaaaaan
  6. The Following 5 Users Say Thank You to MB For This Useful Post:
    Cremulator (5th February 2021), Mickhead (6th February 2021), Plasnart (8th February 2021), Rossco (5th February 2021), rusty_nail (5th February 2021)
  7. #9854
    Haha!!! Great test mate. Glad my logic works!!! I have had this set up on my GQ in 2 different air boxes for the win. Never tested it like that but was confident in its performance and stoked it works as i expected.
  8. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Cremulator (5th February 2021), MB (4th February 2021)
  9. #9855
    Hahahahaha. Plas you need to come for a drive in my GU mate....... i show you happy Dance brother! Lol
  10. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (5th February 2021), Plasnart (5th February 2021), Rossco (5th February 2021)
  11. #9856
    472 Post(s)
    Certainly appears to work Legend
    Nearly Midnight and “Fark It” I says !!
    $790 for the best of the best hocked my spend for hassle free hoping and a best highway design only found
    Why does it take a retard like nuffy me to work out the product has an engine swamping/hydro locking potential?
    Honestly dislike bagging products but if you’re gonna put yourself above China spruiking get that simple test R&D shit underway ASAP Legends.
  12. The Following User Says Thank You to MB For This Useful Post:
    MudRunnerTD (5th February 2021)
  13. #9857
    They do work those little valves. If you have a think about it. When the engine is running there is vacuum being pulled inside the airbox. So with vacuum it pulls the rubber valve inwards and seals not allowing any fluid in. This is why it didn't work in your bath tub.
  14. The Following 6 Users Say Thank You to nissannewby For This Useful Post:
    jack (5th February 2021), MB (5th February 2021), MudRunnerTD (5th February 2021), mudski (5th February 2021), rusty_nail (5th February 2021), Winnie (5th February 2021)
  15. #9858
    461 Post(s)
    Se below a snip from the Donaldson catalog.
    The Vacuator Valve, standard on
    the majority of Donaldson air
    cleaners, is an important part
    of the functionality of the air
    cleaner. It is an integral part of
    the pre-cleaning stage on two stage
    air cleaners.
    The dust cup, where pre-cleaned
    dust is collected, is normally
    under a slight vacuum when
    the engine is running. The
    normal engine pulsing of the
    vacuum causes the Vacuator
    Valve to open and close. This
    action automatically expels any
    collected dust and water. The
    Vacuator Valve also unloads
    when the engine is stopped.
    For the longest filter service life, replace damaged or
    missing Vacuator Valves immediately!
    If your valve is cracked, torn, remains open, or is missing, dust particles that are
    normally expelled can deposit themselves onto the filter and will shorten air filter
    service life. Replace it!
    The Donaldson Vacuator Valve,
    also known as VacValve, is
    made in a variety of sizes
    and shapes to fit various
    applications. The Donaldson
    part number is molded into
    each part for easy identification.
  16. The Following 2 Users Say Thank You to mudski For This Useful Post:
  17. #9859
    472 Post(s)
    Thanks Legends, great learnings as always appreciated
    Not sure how well the vacuum closing design of the valve is going to work if I accidentally stall the truck half way through a deep river or in the middle of a shocking bog hole though
    Wouldn’t that be exactly the same as the bath tub nuffy test?
  18. The Following 2 Users Say Thank You to MB For This Useful Post:
    MudRunnerTD (5th February 2021), nissannewby (5th February 2021)
  19. #9860
    I guess you just need to not stall it then?? Lol
  20. The Following 3 Users Say Thank You to rusty_nail For This Useful Post:
    MB (5th February 2021), MudRunnerTD (5th February 2021), nissannewby (5th February 2021)
