1st November 2014, 07:19 PM
Hardcore
Replacing Rear Trailing arms on a GU, advise please
So today I notice I have a slightly bent lower rear trailing arm, (im guessing from my last glasshouse trip) i was looking at getting these..........
http://www.ebay.com.au/itm/2-Rear-Lo...item540492be1f
They are longer by 16mm (i have a 2 inch lift) and they are also thicker wall to resist damage, i notice my factory arms have some sort of dampener attached to them, so im guessing this is there for a reason, the replacement ones don't have this dampener, so im wondering how important this is ?
So apart from the dampener question, has anyone had issues from fitting slightly longer lower rear arms ?
BTW ,I don't want to go the adjustable lower rear arms to avoid hassle from DOT.
1st November 2014 07:19 PM
1st November 2014, 07:28 PM
Moderator
Dont worry about the dampener. I dont think you need +16mm longer lower arms with a 2" lift though. I would go HD standard length for your setup. I have standard Length on both the GQ and the GU. The GQ is 5" lift and has adjustable Uppers. and the GUIV is a 3" lift and had HD standard Length Lowers from Superiors
Check out my Toy -->
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
04OFF (1st November 2014), Chubba (1st January 2017)
1st November 2014, 09:27 PM
if your pinion angle was fine then all you need are standard length lowers. If you put in longer ones it will throw the pinion angle out.
So a set of HD std length lowers would be the way to go as MudRunner said.
http://www.roadrunneroffroad.com.au/...gth-NPTAB.html
FYI - Its just 2 ways you can adjust your pinion angle after lifts..Either adj uppers and standard lowers, or standard uppers and longer lowers.
The Following User Says Thank You to doka404 For This Useful Post:
1st November 2014, 09:43 PM
Smart like tractor
Standard length only steve,
Unless you go long arms
96 GQ coil/Cab
08 G6eT
1st November 2014, 09:59 PM
Hardcore
Thanks guys, glad i asked, going on your advise, just ordered these........
http://www.ebay.com.au/itm/261643214...84.m1439.l2649
They are standard length and 5.5mm thick wall so should not bend easy, with 10% ebay sale i got them for $211 a pair.
The Following User Says Thank You to 04OFF For This Useful Post:
1st November 2014, 10:43 PM
Moderator
what is the 10% Ebay sale all about? is that just that seller or is it Ebay??
Rogue Dung Beetle
1st November 2014, 11:02 PM
Dribble Master
MudRunnerTD
Ebay gave been doing Sunday discounts, so basically they send you an email with a code. Purchase anything out want, apply the voucher code and get stuff cheaper......... Has to be an eBay run thing, could be wrong though
1st November 2014, 11:28 PM
Moderator
Cool! What is the Code?? keen
Rogue Dung Beetle
1st November 2014, 11:34 PM
I've got a press Steve if you need
The Following User Says Thank You to megatexture For This Useful Post:
04OFF (2nd November 2014)
2nd November 2014, 12:10 AM
Hardcore
Thanks Troy, ill keep it in mind.
Yeh the 10% off thing is legit egay/paypal checkout thing (not from individual sellers), my code was only valid for 4 more days, so good timing me finks
