7th May 2017, 06:44 PM
Evening ppl
Can any body tell me what size bolt I need for
for the engine mount brackets are they fine
thread or course thanks in advance
its a 3l Di
7th May 2017 06:44 PM
7th May 2017, 10:25 PM
SUCH IS LIFE
I wonder if they have the size in the service manual Roofy?
................on the road
________________________
______ 2017 D-Max _______
The Following User Says Thank You to Maxhead For This Useful Post:
8th May 2017, 07:33 AM
Nisshead
Looked in the gregorys manual just says for bolts
might be 9/16 ill know better once I get it apart
8th May 2017, 08:22 AM
SUCH IS LIFE
Sir Roofy
I just checked the normal manual and they seem to have torque specs but not bolt sizes.
Bloody hard manuals to navigate..lol
8th May 2017, 09:16 AM
I'm sure mudski has some new mounts ... He can check bolt sizes , measure up etc ... Maybe ? @mudski
8th May 2017, 09:39 AM
Nisshead
Not wrong there we will survive mate
8th May 2017, 09:40 AM
Hodge
mudski
Thanks mate have to wait till he's free I guess
8th May 2017, 09:56 AM
The mounts don't use bolts, they have studs in them. The bracket is bolted to the chassis. I just check the parts catalog and theres no size written. They will be a metric fine thread. Are all the bolts missing? both sides? I think they are a 14mm head on the bolt, which should be a 12mm (1.5 pitch I think) by maybe 20mm in length. If you can get another out you can use this for reference.
11298VB912 for LHS and 11298VB913 for RHS, are the OEM numbers. 4 each you need for both sides. Not sure why they are different part numbers, most times I see this they are the same part, just different numbers. See if a local Nissan dealer ship can get them? They might be cheap enough from them for the right ones.
8th May 2017, 12:01 PM
Thanks mate yea four bracket ones where missing the ones that bolt to the motor
was very lucky the motor didn't twist out
8th May 2017, 06:09 PM
ITS done now I have to wash the blood off the motor and me
hate 3l motors with a vengeance
shouldn't come loose this time used lock tight
The Following 5 Users Say Thank You to Sir Roofy For This Useful Post:
Bob (10th May 2017), Hodge (8th May 2017), MB (8th May 2017), mudnut (8th May 2017), Rossco (8th May 2017)
