8th April 2017, 09:58 PM
Hardcore
Yendor
The are a few relays that I’m aware of in the LHR quarter panel, there’s two that are part of the rear A/C unit and one for the rear power socket. The power socket relay is mounted at the front of the quarter panel near the seat belt retractor for the passenger LHS second row seat.
The noise isn’t coming from the door lock actuator in the small barn door is it?
Another possibility is a blocked drain tube for the rear A/C??
If the noise is coming from a relay it more then likely won’t be a faulty relay. It will most likely be something electrical that is trying to keep/switch the relay on. Anything electrical been added to the vehicle lately? thermo fans? anything plug into the front cigarette light or power socket?
Thanks Yendor,
It's not the door lock, I think your last sentence may be the answer.
I've recently plugged a couple of new USB chargers into the lighter and power sockets. I notice they have led lights in them and once the car is turned off it continues to light up as it's draining from the battery on the dashcam.
Assuming that's just enough power to cycle the relay till the camera battery goes flat. Going out to unplug it now which I have been doing most times, but I know it's plugged in now. I'll keep you updated, this explains why it's intermittent.
Again thanks for your advice, always like reading your replies to others issues/questions. Knowledgeable and always helpful.
Cheers mate
Jack
The Following User Says Thank You to jack For This Useful Post:
8th April 2017 09:58 PM
8th April 2017, 10:25 PM
Apollofish
Thanks Yendor,
Cheers mate
Here’s hoping that is the cause of the noise, nice and simple.
8th April 2017, 10:45 PM
If you have rear AirCon, could be solenoids related to the gas side of that and the associated bubbling is the refrigerant.
The Following User Says Thank You to Turtle_au For This Useful Post:
9th April 2017, 01:18 PM
Hardcore
It's not the AirCon turtle, I think I may have misled people by mentioning 'bubbling type noise', that was the easiest way to describe it. It's definitely a relay rapidly switching.
Looks like its resolved after unplugging the USB charger, but as it was intermittent I won't count my chickens yet.
Will let it go for a while yet.
Jack
12th April 2017, 09:44 PM
Hardcore
I'm going to call this resolved, thanks Rod (@Yendor)
Jack
13th April 2017, 12:25 PM
So just curious was it a relay in the end?
Just good to know for the future.
13th April 2017, 12:29 PM
#17
Hardcore
Hodge
Yeap Hodge, it was the relay. I misled people by mentioning a 'bubbling noise' for lack of a better way to describe it. Like Yendor said, the relay wasn't faulty.
Jack
13th April 2017, 01:23 PM
#18
Apollofish
Thanks for clarifying...
Always good to know for future reference.
