Page 357 of 565 FirstFirst ... 257307347355356357358359367407457 ... LastLast
Results 3,561 to 3,570 of 5642
  1. #3561
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    For the sake of keeping it legal Im not convinced using a 3" dump without a cat would be noticable
    after all its only a 3ltr
    It's not. Nuff said
  2. The Following User Says Thank You to 4bye4 For This Useful Post:
    threedogs (28th March 2017)
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I doubt there is any measurable power difference with or without a 200 cell cat. I've spent a bit of money on the GVM Upgrade to ensure I'm legal loaded up, so a couple of hundred on a cat to keep the legal theme going on this build is chicken feed really.
  5. The Following User Says Thank You to stevemc181 For This Useful Post:
  6. #3563
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Went to auto8 and got another 10 pack of Anderson plugs , only $29 on spec which is the cheapest in this town .
    Now to set up the solar systems on camper and GQ so they play nice together or don't mind being separated .
    Will take pics and let you know how I end up doing it if anyone is interested .
  7. The Following User Says Thank You to GQtdauto For This Useful Post:
    MB (4th April 2017)
  8. #3564
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Keep forgetting the photo .
  9. The Following User Says Thank You to GQtdauto For This Useful Post:
    MB (4th April 2017)
  10. #3565
    Aug 2014
    Perth
    10 Post(s)
    Not today but on Sunday I bought a Rivnut Kit and some 10mm eye bolts was going to install various rivnuts in my tray and move the eye bolts around as tie down points depending on what I have on the tray. Sick of all my gear sliding around when I'm on rough tracks. Kit does up to 10mm thread
  11. The Following 5 Users Say Thank You to gubigfish For This Useful Post:
    Clunk (4th April 2017), GQtdauto (4th April 2017), MB (4th April 2017), mudski (5th April 2017), Plasnart (4th April 2017)
  12. #3566
    472 Post(s)
    That's awesome, well done GUBF !! Never knew Kingchrome made em, gonna have to get one of them if you don't mind me asking how much $ mate? We've been using elcheapo home made nut&bolt versions onsite as we could only afford one of the pneumatic factory line ones @ $2.5k :-(
    When using Rivnuts/Nutserts for tray mount eyebolts I would like to recommend adding an extra topside backing nut to the eyebolt as the Riv/Serts are very soft and need help with lateral force if that makes sense mate?
  13. #3567
    Aug 2014
    Perth
    10 Post(s)
    That was $138 at Bunnings (https://www.bunnings.com.au/kincrome...t-kit_p5910346) and I think Toolmart over here had them for $145 but pretty sure Toolmart is a WA business. They must have just released it as I was looking at one about 12 months ago from Eclipse but that was closer to or over $200 from memory.
    So eyebolt then a nut with the correct thread before going into the nutsert? I will have to see as the eyebolts screw in all the way but a nut may not have them grab enough thread, unless I have what your saying wrong.
  14. The Following User Says Thank You to gubigfish For This Useful Post:
    MB (4th April 2017)
  15. #3568
    472 Post(s)
    Should've added, when we do need to remove one due to found maintenance torque slippage it's as easy as a long bolt inserted and heaved in circular motions and or nip off the topside sert lip and the guts of it fall inside/down. They are great things, just please don't rely on them for big sideways loads folks :-)
  16. #3569
    472 Post(s)
    Sorry mate, typing same time, takes me ages:-)
    Correct you are, and Cheers heaps for the links, legend :-)
  17. #3570
    Quote Originally Posted by gubigfish View Post
    Been lucky enoung to be using rivnuts from the late 70's seeing
    most my mates work at the Airport.
    As for removing eye bolts is it possible to install some tiedown track
    then you can "click in" an eye bolt where ever you want
  18. The Following User Says Thank You to threedogs For This Useful Post:
    Rossco (8th April 2017)
