4th May 2016, 12:13 PM
#61
When box was off did they check things like crank shaft end play or anything to do with the motor?
4th May 2016 12:13 PM
4th May 2016, 12:16 PM
#62
Was a new spigot bush installed? Was the gearbox input ahaft checked for straightness?
4th May 2016, 12:23 PM
#63
The 747
biggqwesty
nissannewby
No idea on both counts there.
BigRAWesty (4th May 2016)
4th May 2016, 02:09 PM
#64
Winnie
Bugger.. fingers crossed..
9th May 2016, 03:57 PM
#65
The 747
New 2nd hand clutch booster is in and it has fixed the problem. I have got my car back now!
The Following 2 Users Say Thank You to Winnie For This Useful Post:
nissannewby (15th May 2016), Rossco (9th May 2016)
9th May 2016, 04:00 PM
#66
Winnie
Good stuff mate guess you'll be out after work
to see how it goes
9th May 2016, 05:00 PM
#67
mudski
Clutch is still under warranty but I have to pay for the remove and refit..
Was the clutch installed over 12 months ago?
9th May 2016, 05:45 PM
#68
dom14
No it wasn't. But thats all sorted and for another story.
12th May 2016, 01:22 AM
#69
mudski
Yeah, the point I was trying to make is that you didn't have to pay the cost of labour again if the mechanic stuffed it up. Clutch cost peanuts comparing the labour cost. 12 months warranty should cover both parts and labour, at least in the case of clutch replacement.
Otherwise, what is the point? Spare part can be just a couple of dollars as in welch plugs. Then the labour can be hundreds, if not thousands. I remember having to pull the whole bloody engine out of a car, just to do a single welch plug.
29th August 2016, 07:48 AM
#70
The 747
So over 6 months and a lot of money later and I am still having clutch problems... everything in the hydraulic system except for some of the lines (which are not leaking) is brand new. New slave and master cylinder, new second hand booster, new clutch and flywheel.
I'm finding that when I first start the car, the clutch is perfect. But after driving for a while, the friction point of the clutch moves up the pedal. I don't know if it is dependent on temperature, but that's what I'm thinking?
So at first the friction point is pretty close to the floor which is fine. But after 10 mins or so it starts getting closer to the driver. On our last Licola trip it had moved so far the clutch started slipping, I haven't driven the car since this trip though.
Could it possibly be a vacuum issue? Any other ideas?
I am pulling my hair out with these bloody clutch dramas!
