Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 75
Thread: Cross Country Disappointment
  1. #61
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    A few of late have failed. It seems CC'S main welder has left and gone out on his own..
    Hopefully quality issue is sorted soon..
    Yeah I've seen a few faceache post of CC intake manifolds opening up along the welds (dodgy looking beads). Have any coolers actually failed though?
    Patrol God Stropp's Avatar
    31 Post(s)
    Quote Originally Posted by sooty_10 View Post
    mines been on for 3yrs or more and no issues
  4. #63
    461 Post(s)
    Do you get a lot of noise through yours when you accelerating hard @Stropp? Mine is quite loud. I was annoyed with it at first but now are used to it. I did read somewhere a fella moving the mounting tabs on the brackets and using rubber isolators between the cooler and bracket. Apparently made a difference.
  5. #64
    Same here for about the same amount of time. No issues at all.
    I don't get any noise through mine? Not that I could hear it over the 500 other noises that my car makes
  6. The Following User Says Thank You to Winnie For This Useful Post:
    mudski (26th October 2016)
  7. #65
    Bendigo
    7 Post(s)
    Yeah as I mentioned coolers seem to be lasting but the couple of manifolds I have seen pics off opened like a can of baked beans along the seam. Could have been an isolated (apprentice welder) case, however disappointing to see poor quality control if that is the case.
  8. #66
    175 Post(s)
    I get a lot of air rushing noise through mine especially when the boost gets up and going.
    But I've driven 2 others and it's the same. Including Mudskis .
    But it cools, does it's job.
  9. #67
    330 Post(s)
    The CC cooler would be close to those dimensions.
    And that is part of the cost.
    The kit includes new scoop to suit your colour, cooler, new mounting bars, new pipe work etc etc..
    So really on cost point imo there woukd be more work involved in making new fiberglass scoops than suppling a few bends and a bit of pipe.
    The Cross Country web site is bloody average! there seems to be no Shopping cart function! Who Does That! also the kits are not listed with a "Whats in the box" type list. can you guys confirm that the scoop is colour matched and did you supply the colour code at the time you ordered? Did the kit come with a template for the Bonnet cut?
    Can anyone tell me the difference between the GQ cooler and the Ultimate Cooler for the GU? Other than $400? Struggling?
  10. #68
    The GU ultimate is a bit bigger.
    Mine was not colour matched and I did not get the option for it to be. I think it was supplied as white? I can't remember!
  11. The Following User Says Thank You to Winnie For This Useful Post:
    MudRunnerTD (26th October 2016)
  12. #69
    31 Post(s)
    no noise from mine mate??
  13. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    mudski (26th October 2016), Winnie (26th October 2016)
  14. #70
    Advanced Potsy's Avatar
    Jan 2015
    Adelaide SA
    Maybe these variations in noise are more to do with the other things done to the rig, as stropp mentioned "no noise" but I can see he has a 4inch snorkel, I'm guessing then the air box and Inlet to turbo is upgraded. I wonder if this would make the difference. Also with the top mound there is very little pipe between the cooler and inlet, add to that the fan which I believe runs off of the radiator temp and it being sooo close to the driver could add to the noise when running.
    Also as someone who lives in adelaide I'd like to think a lot of the issues people are having are a result of the demand on cross country, I drive past quite regularly and I don't reckon I've ever seen the car park less than 110% full, I'm sure there's cars parked across the road to, hopefully it's something they can address but when they cover so much like car servicing and pre trip checks I can see why they're so swamped. To popular to quick me thinks.
    2000 GU, TD42T, bullbar and roof racks, 2inch lift, winch, front and rear air lockers, 3inch Scotts rods dump and exhaust kit.....more to come!
