Results 1 to 10 of 14
Thread: Best way to keep an idle battery healthy.
    G'day, All. My uncle had the misfortune to watch his Rodeo go up in flames a couple of years ago.
    Fortunately, he was able to acquire an 06-07 GU TD42 ute which already had a canopy and duel battery system installed.
    He runs a 60 litre Engel which is great when he goes away, for 6 months of the year, but the battery seems to run down quickly in the off season.
    I had a look under the bonnet and found that the second battery is only charged via a solenoid, so there is not much of a circuit that will cause leakage.
    My question is this, what would be the best way of maintaining the battery?
    43 Post(s)
    A multi stage charger plugged into 240v while the car is dormant.
    Or if he uses the car weekly the a dc-dc multi stage charger.. to save unplugging all the time..
    You see 7 stage chargers for about $100 these days..
    But if he's getting mass voltage drop over a short period I'd say battery is near toast..
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    mudnut (26th May 2016)
    Will let him know, thanks, Kallen.
    I just bought a ctek 3.8A smart charger for $105 to leave plugged in all the time.
  7. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    BigRAWesty (26th May 2016), mudnut (26th May 2016)
  8. #5
    Charge it at the end of the Season with a "recondition" mode charger.
    Disconnect the Battery until next season.
    Maybe a quick top up in the middle of the "off season"
    If it loses charge that way then the Battery is toast
  9. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    BigRAWesty (26th May 2016), blocko05 (27th May 2016), mudnut (26th May 2016)
  10. #6
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Is leaving the battery hooked up to a solar panel (regulated obviously) going to achieve the same results as a 240v charger? I.e. Maintain/top up the battery level.
    My patrol is hooked up to my solar panel and I have been wondering if I can leave it or I should unplug it then just use it to top the battery up every so often.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  11. #7
    174 Post(s)
    What has been missed so far is to ask what sort of battery it is. A 'wet' battery will behave somewhat differently to a an AGM battery. The latter were originally designed for the armed forces who wanted bateries for vehicles & equipment which were only used from time to time, sitting idle in between. Wet batteries have a much higher 'self discharge rate' & need regular charging to prevent them going 'flat' & bringing about their early demise. AGM batteries on the other hand can be fully charged & then left idle & unused for months at a time. An AGM in good condition left in this way will still be at 80% SOC (State of charge) after say 3 months, & 60+% after 12 months. I don't advise leaving one for 12 months, but charging it to 100% every 3 or 4 months would be fine.
    If it's a wet battery weekly charging combined with a check of of it's fluid levels will suffice. eaving it connected to a mains or solar trickle charge will also do the job, but still wise to check the fluid regularly
  12. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
  13. #8
    43 Post(s)
    Quote Originally Posted by lhurley View Post
    It would but again for best results a dc-dc multi stage charger is best..
    174 Post(s)
    Sorry Kallen, but that just isn’t so. A solar regulator is a multi stage charger & a battery doesn’t care if it’s charge is coming from the sun, an alternaor (via dc to c charger) or from a mains powered multi stage charger. In respect to the OP’s question, the least useful would be a dc to dc charger which requires the vehicle to be used to do it’s job.
  15. #10
    43 Post(s)
    Sorry your right. I should have put more into the answer.. lol
    I was going "best option" along the line of the solar with a dc-dc charger is more versatile, once setup it can be used anywhere..
    But yes when at home if the car I'd sheded for lma long time then the 240v wins
