Page 869 of 1049 FirstFirst ... 369769819859867868869870871879919969 ... LastLast
Results 8,681 to 8,690 of 10488
  1. #8681
    461 Post(s)
    Quote Originally Posted by Yeti's Beast View Post
    Changed both my engine mounts last night. Can’t talk about it as I’m still too traumatized by the experience
    Lemme guess. ZD30. RHS is a royal PIA to do.
    Yeti's Beast (1st November 2018)
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Yep
    But I actually found the left harder.
    I ended up taking the top brackets off the block because with the engine was hard up against the fire wall. My neighbor suggested undo the gear box cross member but that achieved zip. Just more stress.
    Getting those bolts out of the brackets is impossible but I got there eventually.
    The difference is amazing. It’s like a new car.
    Shame I’m selling the car and won’t get to drive it now. It was picked up during the RWC
  5. #8683
    461 Post(s)
    Yep
    From memory doing mine, I loosened the body mount bolts so I could lift the motor up higher. I only did the left on mine but doing a mates GU both were a nightmare. RHS worse I found.
  7. #8684
    Aug 2016
    Jimboomba
    4 Post(s)
    Stupid Nissan, put in a hydraulic mount which worked well but the design of the fittings leave you wondering why.
    It’s like they never thought it would need replacing.
    Step one, fit mount to chassis
    Step 2 fit bracket to block
    Step 3 lower engine into engine bay and secure mounts
    Step 4 hope it never needs replacing
  8. The Following 3 Users Say Thank You to Yeti's Beast For This Useful Post:
    GQtdauto (1st November 2018), MB (1st November 2018), mudski (1st November 2018)
  9. #8685
    Had the Auto serviced this morning on the mighty GU
  10. The Following 3 Users Say Thank You to threedogs For This Useful Post:
    MB (1st November 2018), mudski (1st November 2018), Yeti's Beast (1st November 2018)
  11. #8686
    Thought about washing it
  12. The Following User Says Thank You to Avo For This Useful Post:
    MB (2nd November 2018)
  13. #8687
    49 Post(s)
    Nothing yet, but after walking pass and seeing this.....
    Looks like engine oil, couldn't see from where it's coming from, any ideas...
  14. #8688
    175 Post(s)
    You sure it isn't power steering oil ???
  15. The Following User Says Thank You to Hodge For This Useful Post:
    jay see (2nd November 2018)
  16. #8689
    49 Post(s)
    Haven't had a chance to had a proper look. Just ran my finger over it. Did see the p/s hoses and they are dry.
  17. #8690
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    If it's power steering oil the level should have dropped a fair bit ,I'm looking at putting a kit in mine but having trouble working out which kit and why the big difference in price between them .
    By the look of all that oil you should be able to work it out from the colour .
  18. The Following User Says Thank You to GQtdauto For This Useful Post:
