2nd April 2018, 05:49 PM
2010 CRD Clutch pedal problem
Hi guys,
been a long time since ive been on the forum which i guess could be looked at as a good thing! no problems for a while for the old girl!
I have however just recently noticed that whilst driving for a while (30mins+) the clutch pedal starts to get about an inch of freeplay at the top before it starts actually moving anything. the rest of the stroke i think feels a bit spongy, this spongy feeling could be in my head though.
The freeplay seems to be related with time and speed (after 30mins on freeway) and less common on shorter drives. It will also still be there after shutting the car down for 10 minutes. The actual clutch engagement is the same, no slipping or shuddering or any other symptoms, just the pedal.
Any ideas?
Im lost about this and is starting to bug me.
cheers
Jarrah
2010 CRD Wagon, ARB Sahara, duel batt, uhf, winch, 2inch lift, 2.75 Beaudesert, 33" Mickey T atz 4rib, spotties, drawers, roofrack, Autometer boost pyro + much more
http://www.nissanpatrol.com.au/forum...7-CRD-ST-Wagon
2nd April 2018 05:49 PM
2nd April 2018, 10:23 PM
booster ? there is not much there .
3rd April 2018, 07:44 PM
Get the Patrol tested for any vacuum leaks. Have you still got the heat shield on the slave cylinder? These often fall off. The slave cylinder could be getting too hot as the exhaust is running right past this. A bigger exhaust will amplify the issue too. You can wrap the pipe up with some header wrap. I did this on mine.
4th April 2018, 10:42 AM
mudski
ill have a look. ive just bled the whole clutch system as the fluid was quite old and didnt look very clean. thinking it might have been some water in there. will see how it goes next big drive.
i do have an exhaust mod but ive had that since new and problem has only just started.
cheers for the feedback, ill looking into the heat shield.
1st June 2018, 06:07 PM
How did you go with your clutch Jarrah, curious to know if fluid change fixed the problem.
