Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Breaking down at 3000-3500 tom
    Mar 2015
    Boyne Island
    @Patrolgrub any up date on your problem???
    Yeh I disconnected the battery again and left it off for until this morning just to make sure the computer reset and it seems to have worked. I had it off for well over an hour the day I did the work but apparently that wasn't long enough.
    Mar 2015
    Boyne Island
    Quote Originally Posted by Warwick89 View Post
    3500rpm?? is it normal for us CRD owners to have revs that high? mine would be going crazy if i used that much throttle.
    Ok never had the issue before I did another reset of the computer and now reving to 4000 clean as has done before but this is good to know cheers for your input appreciated mate.
  4. #13
    Mar 2015
    Boyne Island
    Manual or auto? I have an auto and i would rarely get above 2800, 3000-3300 if I'm really pushing it.
    I have auto and it goes to 4000 easy have seen it get over that before but backed off real quick. Drive it like you stole it I say. Besides if it goes bang then the misses won't hesitate in a power upgrade. Got to see the good side of everything I suppose. 😂😂👍
  5. The Following User Says Thank You to Patrol grub For This Useful Post:
    Warwick89 (21st March 2017)
  6. #14
    Mar 2015
    Boyne Island
    Well after a week of running around the issue has popped its little head up again. Had my mate from carline put his scan tool on and no errors and everything seems to be ok ie rail pressure at 116000kpa on accelerating air flow I think was around 53lit/min on idle so back to the drawing board on this one. Only thing I didn't check was boost pressure. Does anybody know what sort of air flow should be reading on idle
    Cheer all.
  7. #15
    Have you serviced the MAF sensor.
    you could hook a temporary boost gauge up to see whats going on
    using a patrol boost sensor adaptor
    http://www.ebay.com.au/itm/Quick-Fit...8AAOSwsW9YwbzA
  8. #16
    Mar 2015
    Boyne Island
    Ok cheers I have a scan gauge coming shouldn't be far away I spoke to Berrima diesel and they said to check fuel filter as at the revs I'm talking and the symptoms to them sounds like fuel starvation issues. Thoughts on this?
  9. #17
    Are there any inline cage filters that can be inspected ??,
    Ran a tank dry recently,??
    I always leave 10-15 ltrs in my sub tank
  10. #18
    Mar 2015
    Boyne Island
    I usually do the same by filling up aroun 1/4 tank but did a trip a few weeks ago and got down a little to low gor me also last rank of fuel was Costco have you herd any bad reports about their fuel at all and no I can't locate any accessible filters. Appreciate the help it's doing my head in.
