17th December 2017, 08:50 PM
Gq Vacuum canister tank.
I was having a look at the rd28 supp and noticed this tank that I thought might be emission related but turns out to be a vacuum canister. It is not there in my car and some one has fitted an air horn pump. Now I have removed the pump but want to know if it is a vital thing to have. I have heard that it is for brakes and clutch but I am not sure as the car won't be here until next week and want to get a RWC done so want to cover as many things as I can. Pic for attention. Is it ok not to have this installed?
17th December 2017 08:50 PM
17th December 2017, 09:05 PM
Administrator
100% need it mate.
Some of us need more, low revs no brakes it's a must have!
17th December 2017, 09:08 PM
AB
100% need it mate.
Thanks mate I will get onto it asap. I didn't think of the low revs part makes scence. Cheers
17th December 2017, 09:30 PM
WOW, look at all that room under the bonnet!
The Following 3 Users Say Thank You to PeeBee For This Useful Post:
AB (17th December 2017), GQtdauto (17th December 2017), MudRunnerTD (17th December 2017)
17th December 2017, 09:51 PM
Moderator
mad66
It is interesting that yours dosent have one yet is drivable. I would suggest it might have been relocated as you will simply have almost NO Clutch and certainly No Brakes. I had a split vac hose on my GQ 9nce and had Zero brakes! I had to pull up with the hand brake and use rescue tape on the pipe.
I'd say it is there somewhere or a smaller one is there.
Check out my Toy -->
Rogue Dung Beetle
17th December 2017, 10:03 PM
Interesting I will have a good look to see. but what I did notice I a few vac lines going nowhere. brakes are good and so is clutch so not sur yet, will get back as soon as I have a good look.
17th December 2017, 10:17 PM
Yeah agree must be one somewhere else. I had no vac in the clutch the other weekend and was a prick of a thing but no vac to brakes would be defiantly undriveable they would be terrible. . .
18th December 2017, 03:53 PM
MudRunnerTD
Doesn't that make it a little bit unsafe?!!!
Are there any counter measures built into diesel engines to prevent that from happening on the fly?
I mean losing brake boost due to loss of vacuum is one thing , but losing brake entirely can be trouble, particularly if the car's moving fast enough.
18th December 2017, 06:08 PM
Moderator
dom14
It happened to me on the freeway. it wasnt until i was pulling into the service centre to refuel that i realised i have Zero Brakes. change down on the fly then handbrake to a stop worked fine. Emergency braking would have been out of the question though.
If the OPs car is drivable and has brakes i think there will be a Vac Can somewhere.
Rogue Dung Beetle
dom14 (18th December 2017)
18th December 2017, 06:12 PM
Moderator
mad66
So i am in front of the computer now and looking at your pic on the big screen. That canister you have pointed too is a secondary tank. See the smaller tank behind the coolant reservoir mounted to the side wall will be linked into the system and is the Only tank i have on the GQ.
Rogue Dung Beetle
