Results 11 to 20 of 22
Thread: Sleeping in a 2007 Nissan Patrol?
    581 Post(s)
    I've tried the sideways sleeping before (179cms) and it's not uncomfortable.. but for the life of me I've never been able to sleep properly like that. I'm not normally a precious sleeper either.
    I'm not saying don't try it.. but maybe have a back up if you're out for a few nights.
    Yep that must be horrible blokes sleeping sideways in the back?
    I’m 190 something which is not possible but even if you can “just” fit in I would hate that!
    Just roll down the back of the front passenger seat and sleep in that... more comfortable than the 2nd row.
  4. #13
    201 Post(s)
    Yeah I agree with this. While still pretty crappy it is much better than trying to squeeze into the back seat.
  5. #14
    Dec 2018
    Warnbro WA
    In my 2001 GU I found that moving the front passenger seat fully forward take the head rest out & lay the backrest down fully it just squeezes in to the rear seat & lays nearly flat & was pretty comfy
    Bri
  6. #15
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    08 GUIV sleep in the back often with the Engel for company(winter warmth), have double draws in back with mid row(rear) seat back folded fwd with tool bag on floor behind drivers seat and packing on top of tool bag to level single mattress out. Good night sleep, could do two singles side by side with fridge outside.
    U have rear seats in (don't know how they would level out folded down) but could do similar as I do - fold both 2nd row rear set backs fwd, leave rear "dicki" seats folded up out of the way and on the floor in the back between the 3rd row "dicki" seats put a box or knock up a central infill structure(open ended for gear access) like shaped "thingo" to level out mattress. Fill in cavity behind front seats and should be good.
  7. #16
    Well i'm 180 and i had no issue. Knees bent a bit overnight, but so be it.
    Im 183 or used to be now Im 180, I have a 2.5mtr awning you can use roof racks,
    I mounted mine to a piece of 50x25 rhs enclosed both ends with brackets
    and you can enclose it with cheap awning walls,then
    I sleep off the ground in a swag on a stretcher, never sleep on a lilo even with a ground sheet you will freeze
    You could make a pull out floor with a bespoke made tarp to cover th rear doors that would keep you dry
    Only yesterday saw a pull out floor in a dual cab , at Trek Hardware but check your local Decent 4x4 supplier
    Self inflators are a great idea,, bulky but great
  8. #17
    May 2016
    lower west victoria
    30 Post(s)
    Yeah I'm with Clunk. I've tried rear seats and they've never worked for me. I can sleep in front seats if I support my arms with a few pillows or whatever.
  9. #18
    472 Post(s)
    Go with your initial ply board idea up top mate and or inside possibly too.
    Personally can’t sleep too well either unless quiet level flat with legs stretched out straight to function/drive again safely early the next morning.
    Depending on overnight temperatures and without in cab heating it can be horrible trying to sleep inside a tin can Esky, certainly dangerous practice in the mountain areas.
    Consider a Super Cheapo swag off the cold ground or up top away from critters if your bladder will kindly permit 6hrs kip!
    BrazilianY60 (13th October 2023)
  11. #19
    Jun 2018
    24 Post(s)
    I did a night away the other weekend with mates and slept in the car.
    I took the fridge (which I didn't have last time I slept in the car) but a single inflatable mattress from Kmart fitted perfectly and was very comfortable.
    I could lay flat with my feet at the barn door and didn't need to move the front seat forward. I'm 185cms.
    Just temporarily fitted the cargo area seat, folded them both forward and they provided great support for the mattress.
  12. The Following User Says Thank You to Cremulator For This Useful Post:
    MB (10th August 2019)
  13. #20
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    i’ve got a much simpler solution - i tend to drink A LOT & find i can sleep anywhere - under the car , on the wood heap , draped over the spare wheel like a fake fur 👍🏻
  14. The Following 7 Users Say Thank You to Sprock For This Useful Post:
    Avo (10th August 2019), BrazilianY60 (13th October 2023), MB (10th August 2019), PeeBee (10th August 2019), Rossco (11th August 2019), rusty_nail (10th August 2019), Winnie (10th August 2019)
