10th July 2018, 10:46 AM
PeeBee
Can you detect any wear or flat /sticky spots in your accelerator cable/linkages or slop in the pedal at 1800rpm ?
Nah, it feels fine bro
10th July 2018 10:46 AM
10th July 2018, 10:48 AM
nipagu7
so far i would be inclined to go for some injector cleaner or possibly even some 2 stroke oil as i think it is sounding more like an injector issue . the primer being soft when running i think is normal as fuel is constantly being sucked thru it . i think it could be a sticky valve issue but i think you would hear that . fitting a lift pump might confuse or disguise the problem , so i would hold off on that until the problem i found and sorted .
I'm leaning towards injectors. Any injector cleaner you'd recommend? Or is it much of a muchness between them really?. Also, what sort of sound would a sticky lifter give out?.
10th July 2018, 11:33 AM
if it is a sticky valve or lifter you can generally pick it as a ticking/tapping sound coming from the rocker cover , give the car a bit of a rev with the bonnet up and you can usually pick it . any decent quality injector cleaner will do the job , i think cem cleanpower is probably about the best of the bunch . it's supposed to clean the whole system . i would keep an eye on the fuel filter and if it seems to be blocking change it . come to think of of it , i have come across fuel filters causing a similar problem . if your filter is getting near changing maybe change it first and then add the injector cleaner and keep another spare fuel filter just in case it is required .
10th July 2018, 11:36 AM
sorry , just reread you've got a new filter already . so mabye just add injector cleaner and keep an eye on the filter .
10th July 2018, 01:42 PM
nipagu7
Nothing from the norm, just the general tappet noise. I'll give that injector cleaner ago , before hand I'll pull the guaZe out and give her another clean. cheers mate!
10th July 2018, 04:30 PM
Gday mate.
Id say you've got an air leak somewere...only small though.
The primer pump should be firm all the time.
The small o rings on filter drain gave me the same problem a while back.
Get some clear hose and put between filter and pump,it'll show any air bubbles.
10th July 2018, 06:25 PM
#17
Deano2506
Gday mate.
Clear hose from the primer/filter to the inlet hardline for the ip then run the car?. Or will just pumping the primer whilst having the hose coming off the primer outlet show up if there is air?
10th July 2018, 07:07 PM
#18
Clear hose from filter/primer to pump,then run.
If there's any air leaks you'll see em
10th July 2018, 07:29 PM
#19
Deano2506
Cheers, I'll do it tomorrow.
