Results 31 to 38 of 38
Thread: Best way to remove dent on fold rear quarter
  1. #31
    if only you were close ...
    fix it at licola if he can wait that long haha
  2. The Following User Says Thank You to rusty_nail For This Useful Post:
    AB (16th April 2018)
    Darren was my navi and we lived off beer, meat and cheezels for 5 days in the GQ.
    Trust me it didn't work...lol
    Yeah AB was feral
    rusty_nail (16th April 2018)
  6. #33
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Quote Originally Posted by happygu View Post
    That dent is not coming out without paint damage.
    Removing the inner trim will give you access to get in there, but since the fold/crease line is damaged, it will take a lot of beating, and pulling to get it straight again. To get it straight properly, the paint needs to be taken back to bare metal.....
    Yehx2. The paint will get damaged here. Go get a cheap set of panel hammers and dollies, useful for may situations not only dent removal. No panel beater but have certainly done some of my own (not pro job but looks ok. Take the inner panels away, access the best you can, work on area gradually from outside towards center area, bit at a time. Start off by applying pressure around outside area with say lever and padded on end see how things flow. Maybe tight to swing a hammer in there but tap away with dolly on outside to provide support to the metal. Use a selection of hammers work away you will find combo that work best for you. Don't worry about the paint work as it will be the decide. Give it a go mate.
  7. The Following User Says Thank You to Bidja For This Useful Post:
  8. #34
    581 Post(s)
    Yep little too tight to swing a hammer unfortunately.
  9. The Following User Says Thank You to AB For This Useful Post:
    Bidja (16th April 2018)
  10. #35
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Why fix it when ya only gunna break it again? Just hit the other side the same and call it a limited edition
  11. The Following 3 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    Bidja (16th April 2018), GQtdauto (16th April 2018), Rossco (16th April 2018)
  12. #36
    Jul 2017
    37 Post(s)
    It will be worth heaps, production run of one only...
  13. The Following User Says Thank You to Bidja For This Useful Post:
    AB (17th April 2018)
  14. #37
    581 Post(s)
    Nah you can't leave it like that otherwise you give up and it turns into a bush pig!
  15. The Following User Says Thank You to AB For This Useful Post:
    Winnie (17th April 2018)
  16. #38
    weld lugs on it and use a slide hammer n heat,you will need to touch it up withb a bit of filler n shit,maybe the easiest way top go about it
  17. The Following User Says Thank You to Avo For This Useful Post:
