27th August 2017, 11:39 AM
Engine stalling once warm
Hey lads and ladettes,
New the forum so hoping im posting in the correct place,
i have and issue with my patrol that causes it to stall once it warms up, it a 98 tb45e, Theres no coughing, spluttering or shuddering at all, It drives absolutely perfect apart from this little gremlin, best way i can describe it is, if you were driving along and turn your ignition off, sometimes i don't notice the engine has stopped running until i start to slowdown,
a mate of mine who is a mechanic at Holden suggested the crank angle sensor may have gotten heat shock but its just a guess as he doesn't know to much about Nissan'ssta
so i am wondering if anybody has experienced this type of problem and could point in a better direction of fixing it
any help muchly appreciated
thanks peeps
27th August 2017 11:39 AM
27th August 2017, 09:09 PM
pachydermatous
thanks peeps
Not getting the above bold letter part when comparing it with the original claimed issue of "engine stalling when warmed up".
31st August 2017, 08:51 AM
I don't know about Nissans, but faulty crank position sensors in Hyundai cars cause this exact fault.
If you can measure the resistance of the sensor & compare to a known good one or have the specification, the faulty one will most likely be high.
Graham
31st August 2017, 11:34 AM
A lot of VS / VT era Ecotec commondoors had issues with the crank angle sensor when hot they stop the motor ....
I used to poor a bottle of water on the sensor and car would start right up. It was a C*** of a thing.
Maybe try that first
