Page 254 of 262 FirstFirst ... 154204244252253254255256 ... LastLast
Results 2,531 to 2,540 of 2619
Thread: The Knife Thread
  1. #2531
    Quote Originally Posted by oncedisturbed View Post
    Need to get myself one of those mini belt sanders
    "Never under estimate the power of the tap, let it flow through you"
    Milion and one uses the guys at JB HIFI use them when they modifiy or make up consoles
    I love it even an air one would do.......$100 RRP
    update on the up swept skinner,,,,Ive selected some streaky buffalo horn
    cause I think the mosaic and the brass pins will highlight better.
    Its a bit tricky as I need to shape it first as Im recessing it on the spine
    and butt. After that it will have a bevelled edge on all sides.still
    need a bit more sanding to shape it right,but you get the picture.
    If ran out of sand paper for my power file and with the Patrol parked
    have no way of getting to Bunning for more Grrrrrrrrr
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Did a bit of messing around with the trackers on some medium density wood to see how the went with basic kindling, cuts through like butter and no change to the edge.
    Will be interesting making a sheath for them due to their shape, thinking I may have to order 2 cheap sheathes and use them for templates
    Going to try out on some jarrah tomorrow and see how it goes
    www.swat4x4.com
  4. The Following User Says Thank You to oncedisturbed For This Useful Post:
    threedogs (20th November 2016)
  5. #2533
    this small hatchet arrived,, good size and weight imo
    Waiting on bits and pieces for the knife Im making.lol
  6. #2534
    Feb 2012
    30 Post(s)
    That's a nice looking axe, where did you find that?
    I use those sharpeners daily and they're very good, basically all I use now
    www.swat4x4.com
  7. #2535
    Yeah I brought a few the day you told me about them,
    boy do they vary in $$$ like those pencil sharpeners,
    anything from $5 to $35.
    The hatchet has an area on the spine a sort of anvil where
    you can hit it with a hammer or such.
    Ill find the link and put it here didnt break the bank either.
    Ive found quite a few different hatchets as well to add to my modest collection lol
    http://www.ebay.com.au/itm/142042006...%3AMEBIDX%3AIT
  8. #2536
    Feb 2012
    30 Post(s)
    This 1 I like
    http://m.ebay.com.au/itm/Tactical-To...%257Ciid%253A2
    www.swat4x4.com
  9. The Following User Says Thank You to oncedisturbed For This Useful Post:
    threedogs (2nd December 2016)
  10. #2537
    Bit the bullet so to speak and purchased this hatchet.
    Perfect match for my Schrade Uncle Henry Golden spike or Pro-Hunter
    http://www.ebay.com.au/itm/291768629...%3AMEBIDX%3AIT
  11. #2538
    This knife arrived today nice weight.... its just a replacement,
    That mosaic pin is awesome there are 20 wire pins inside a 3/16th
    tube.
    The knife is ready to go straight out of the box,very sharp, nylon sheath
    which most knives come with these days
  12. #2539
    This very nice hatchet arrived just now, will match
    perfectly with my Schrade Golden spike and pro hunter
    LATE EDIT, its very sharp straight out of the box,
    could use a flat spot behind the head so you can hit
    it with something
  13. #2540
    some japanese whet stone also arrived two green and a red/white.
    the green are 4000 grit the ruby is 3000grit the reverse side is 10,000 grit
    and shiny as a tile
    All are very fine IMO
