Page 364 of 564 FirstFirst ... 264314354362363364365366374414464 ... LastLast
Results 3,631 to 3,640 of 5640
  1. #3631
    Nov 2010
    Getting a life...
    38 Post(s)
    After the wheel alignment guy said my front wheels are about to fall off I bought bearings.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  2. The Following User Says Thank You to katwoman For This Useful Post:
    GQtdauto (12th April 2017)
    Oct 2010
    Old Bar, NSW
    http://www.allfourx4.com.au/epages/s...on=ViewProduct
    So fed up with the Warn winch I have now, every time I want to use it, it fails! That's 2 Warns kark it in 12 years, for what they charge I was hoping for a better service life.
    Snigging firewood logs Tuesday and it died again aarrrgggh.
    The brushes get stuck in the slides they are located in and as the motor is not solidly attached to the winch it moves around and pushes the little buggers away from the commutator. This is the 6th time I've tried to fix this.
    So a 12000lb fits, up from 9500lb and hopefully ticks the boxes. About half the price of a Warn too.
    Macca
  5. #3633
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Should'nt have any trouble with that iv'e got an iron man and have snigged logs with it lol not as flash as your new one
  6. The Following User Says Thank You to Sir Roofy For This Useful Post:
    macca (13th April 2017)
  7. #3634
    Probably better then the small brackets they sent me with the bar...
    You can buy a bracket to suit the way you're mounting your bar.
    I brought a pair so I can fit a 42" single row along the side.
    I'll try and find the link again, or just type in bullbar brackets
    Sunyee and Vic Off Road sell them for about $20 a pair
    just need to find the correct size. Protect your bar with a
    few wraps of electrical tap when fitting them.
    http://www.ebay.com.au/itm/Pair-2-Bu...cAAOSwhOVXdyp2
  8. The Following User Says Thank You to threedogs For This Useful Post:
    Hodge (13th April 2017)
  9. #3635
    I had one of those and it was a great winch. It did get full of water though.
  11. #3636
    I have the email address of Steve from Warn USA if you'd like to have a chat.
    I speak to him on a regular basis
  12. The Following User Says Thank You to threedogs For This Useful Post:
  13. #3637
    Oct 2010
    Old Bar, NSW
    Looked at reviews Winnie and water was noted by one and heaps of others said they had no problems, the question is if the actually serviced them and had a look inside.
    That was the trouble with the Warns, water did get in but not all of it drains out of the drain hole. On a warm day it condensates all over the insides causing corrosion.
    Macca
  14. #3638
    you could pressurise it using an airhorn motor and a needle valve.
    You'd need to drill and tap a hole for the air fitting
  15. #3639
    175 Post(s)
    Thanks John. That makes life a whole lot easier .... I was gonna drill a hole from each side , in line with the threads of the bar and then push the bolts through that way ... But those brackets you linked would be perfect !
  16. The Following User Says Thank You to Hodge For This Useful Post:
    threedogs (13th April 2017)
  17. #3640
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    You spend mega bucks on a winch and have to fit something to keep the water out and the thing plays up , $199 from Aldi and still going strong after 4-5 years and got me out of trouble heaps of times .
    Also used it to straighten the shed and pulled a few stumps out .
  18. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    Hodge (13th April 2017), mudnut (13th April 2017)
