Results 1 to 10 of 10
Thread: Legal and certified child restraint point with drawers installed for a GU
    Beginner Wackyrider's Avatar
    Jul 2018
    Seems like info is hard to come by for options to have child restraint points installed in a GU while having drawers installed similar to the Kings ones.
    After much trawling online there were rumours of being able to install restraint points in the roof but not much info online so thought I’d chuck up a post.
    You need to pop off the roof lining (no need to remove completely, just slide it to the front of the car) to show the rear support beams near the barn doors.
    Closer look at the specific location used. It is double plated so plenty of strength.
  2. The Following User Says Thank You to Wackyrider For This Useful Post:
    MudRunnerTD (7th June 2019)
    Jul 2018
    You will need a magnetic pick up tool to make your life easy here. Place the dimpled washer from the large hole in the right of the pic in the above post. It should locate itself easily enough over the hole.
    Then use the magnetic tool again to place the nut and spring washer. A small screw driver is your friend to keep them in place while you detach them from the magnet.
    Start the bolt threading on by hand slowly till you can feel it grip the threads. Then get a spanner onto the nut through the same opening. Little tip to stuff a rag over the column that holds the tail light in case the spanner slips out of your hand.
  5. The Following User Says Thank You to Wackyrider For This Useful Post:
  6. #3
    Jul 2018
    Torque her up while ensuring to keep the restraint point straight. I just keep it slightly off centre and then tighten the point clockwise once torqued to ensure I didn’t loosen it.
  7. The Following 3 Users Say Thank You to Wackyrider For This Useful Post:
    Cremulator (8th June 2019), MudRunnerTD (7th June 2019), rusty_nail (7th June 2019)
  8. #4
    Jul 2018
    Lastly slice a cut into the roof lining to allow this to go around the restraint point.
    I used both the spacers that came in the kit to give me the height I wanted.
  9. The Following User Says Thank You to Wackyrider For This Useful Post:
  10. #5
    330 Post(s)
    Outstanding thread mate!! Thanks for your effort here
  11. #6
    Well done mate, 6 months since we spoke about this. Excellent build thread!!
  12. #7
    Jul 2018
    I know. Took me a while lol. Now I can finally fit the drawers in the Patrol. Just thought I’d document it while I was doing the install seeing as I struggled to find much info when I looked.
    Cheers for the info though, got me chatting to engineers once I knew it could be done.
  13. The Following User Says Thank You to Wackyrider For This Useful Post:
  14. #8
    Oct 2018
    Quote Originally Posted by Wackyrider View Post
    hey mate, where did you get your anchor point kit from? im keen to try this!
  15. #9
    Jul 2018
    Quote Originally Posted by JoelyMoley View Post
    Just from Supercheap or the like mate. Make sure you talk to an engineer before you do the work. You just want to ensure they’re happy with you doing the work yourself. All engineers are different.
    https://www.supercheapauto.com.au/p/...-kit/3181.html
  16. #10
    Mar 2023
    Hey Wackyrider
    I am just putting in these tethering points in now. I take it your able to put 2 anchor points up the the carrer rail above the barn door right? One on the left hand side and the other on the right hand side?
    You are right it's not easy to find information on anchor points. Even the baby stores that I've visited so don't have any information on where to go to install the points.
