2nd July 2017, 01:09 PM
#191
Great idea, yes pics please. Also just realised it must go in the corner of the box as the big round pot would not allow it where it near touches the center walls! I think you mean here below is best mate?
2nd July 2017 01:09 PM
2nd July 2017, 01:58 PM
#192
The Following 2 Users Say Thank You to MB For This Useful Post:
Clunk (2nd July 2017), PeeBee (2nd July 2017)
2nd July 2017, 02:14 PM
#193
The Following 4 Users Say Thank You to MB For This Useful Post:
Bacho86 (3rd July 2017), Clunk (2nd July 2017), gubigfish (2nd July 2017), PeeBee (2nd July 2017)
2nd July 2017, 02:47 PM
#194
And finally in goes 1kg of Spuds, one Turnip, one Leek, 500g bag of Garden Peas and I'll let the coals completely burn out ready warm for dinner tonight!
Ooh, and the Onions & Garlic went in towards the end of hot smoking the bones earlier.
The Following 3 Users Say Thank You to MB For This Useful Post:
2nd July 2017, 02:59 PM
#195
The 747
Loving it Mark! Inspiring stuff.
The Following 2 Users Say Thank You to Winnie For This Useful Post:
MB (2nd July 2017), PeeBee (2nd July 2017)
2nd July 2017, 03:21 PM
#196
Cheers Chrisso mate! Just for reference on your oven adventures, when the inside box is around 200C a 'full' pot of liquid will boil 'moderately' with around a dozen coals on top. I am now removing a redgum chunk off the top top as it was starting to overboil!
EDIT: Scrap that above, had to remove 'all' coals now off the top.
EDIT 2: I'm thinking that the bones have finally reached 100C much like Plasnart's Youtube 'Primitive Technology' bloke uses hot rocks to boil water in clay pots! Have now put a 20mm stick under the lid to let some heat out as it was increasing in boil rate going off its head! (Finally simmering now)
2nd July 2017, 04:40 PM
#197
OK, couple of pics and a back flip as well!
The hole in the side of the oven does not work because the head of the thermometer is too heavy and it tips up and would rest against the hot tray, so drill a hole in the rear corner so the probe sits approx 20mm off the wall. the probe length then can be up to 200mm long from memory, so plenty of options regards finding one. Keep the head or dial away from the hot coals, but you can always simply remove the probe when replenishing the coals on top.
The probe i have used is one from BBQ galore from memory and it has both temps and also cook tenderness bands for different meats. The probe is approx 125mm long and dial 45mm diameter.
The smaller ones are for direct placement into the meat and have a 25mm head and 50mm prong. I used these for the venison at the camp oven cook off and they worked a treat.
The hole i have drilled in the side of the oven will be welded up when I get a chance.
Thanks guys for the continual upgrade advice and suggestions. It all helps to make this even better as a cooking device.DSC01740.JPGDSC01741.JPGDSC01742.JPGDSC01743.JPG
The Following 3 Users Say Thank You to PeeBee For This Useful Post:
Clunk (2nd July 2017), MB (2nd July 2017), Plasnart (15th November 2017)
3rd July 2017, 06:38 AM
#198
The 747
MB
How was it in the end Mark?
3rd July 2017, 07:10 AM
#199
Not too bad at all mate, probably too many Spuds though, went a big thick after mashing.
3rd July 2017, 08:15 PM
#200
