Page 790 of 1049 FirstFirst ... 290690740780788789790791792800840890 ... LastLast
Results 7,891 to 7,900 of 10488
  1. #7891
    May 2016
    8 Post(s)
    slowly slowly catch the monkey ! It should come back together ok . tack here and there !
    its like fixing motorcycle seat baces !! at least its not rusty
  2. The Following User Says Thank You to Tip12345 For This Useful Post:
    mudski (29th August 2017)
    461 Post(s)
    Quote Originally Posted by sooty_10 View Post
    Ouch.... is that the floor pan? How much did the bloke who owned it before you weigh?
    And is the seat cushion reasonable $$$?
    Thats the seat pan which the cushion sits in and bolts to the rails. I'd have to go through my receipts but I think it was around the $150 mark. Dont quote me on that, it was quite a while ago.
    So when I fix the pan I have to work out how to attach the seat cover to the cushion and pan again as it was held in with copper rings that I had to cut off. this part might be for an upholsterer to do...
    This is the under side of the seat pan. The pliers are pointing to the cracked area. I washed the seat cover too in the laundry tub. Holy shite! The water went like mud instantly. So I had to wash it multiple times over. Now I wanna do all the seats but its a way too big of a job.
  5. #7893
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    It never ends @mudski - STOP LOOKING 😝 . I took my Rallye 4000 driving lights fitted with HID inserts off & replaced them with LED driving lights , I took 2 of the LED driving lights off the truck as there was no difference between the 1st 2 then after adding another 2 . Putting the HIDs on the truck for more distance- in between the LEDS for spread . Also cut the plate out of the top of the bullbar between the lights & mounting the remote box down in there - been temporarily mounted elsewhere for the last 6mths .....
  6. The Following User Says Thank You to Sprock For This Useful Post:
  7. #7894
    80 Post(s)
    Try the gal coated netting clips. https://www.bunnings.com.au/whites-1...-pack_p3064754
  8. #7895
    461 Post(s)
    All fixed and seat put back together bud. I found a motor trimmer who works from home almost within walking distance from me. I took it around and he put the cover, foam and base back together on the spot for me and charged me a whole $10. Win win. The seat feels real different to sit on now, I don't fell like Im sinking in the seat, and the handle to adjust the front tilt now works, whereas before it wasn't because of the broken mounts. Love it!
    Now to attend to these bloody seat belts which have stopped retracting, again.
    Stropp (29th August 2017)
  10. #7896
    Nov 2010
    Getting a life...
    38 Post(s)
    I use the carpet cleaning machine to do my seats. And my father-in-law was a trimmer, so steve has the know-how and tools to do the seats. He's pulled out and repadded every GU seat we've owned.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  11. The Following 2 Users Say Thank You to katwoman For This Useful Post:
    mudski (29th August 2017), Stropp (29th August 2017)
  12. #7897
    461 Post(s)
    Yeah I watched the guy put it all back together. One tool and a those clips. He was done in 5 minutes. I asked the guy about washing the covers while they are still on the seats. He said to be real careful because if the foam is not in the best shape the moisture will destroy the foam real fast when you are trying to vacuum out the moisture. Its best to use the foam stuff in a can you get from auto shops he reckons. Or remove the covers entirely and wash them. More work but I think I will do the latter, one day. More work on the to do list... :P
    Edit : Just ordered the hog ring pliers and a packet of rings. Gawd! Now I will have to do all the seats.
  13. The Following 2 Users Say Thank You to mudski For This Useful Post:
    katwoman (29th August 2017), Stropp (29th August 2017)
  14. #7898
    Patrol God Stropp's Avatar
    31 Post(s)
    Had the emu wings fitted, look great and very easy access to the back now
  15. The Following 4 Users Say Thank You to Stropp For This Useful Post:
    Bacho86 (2nd September 2017), MB (2nd September 2017), Rossco (2nd September 2017), Woof (2nd September 2017)
  16. #7899
    472 Post(s)
    Found my vacuum leak today, will be an easy fix thankfully:-)
    https://youtu.be/kpZwpkyhqyg
  17. The Following 2 Users Say Thank You to MB For This Useful Post:
    Hodge (2nd September 2017), Rossco (2nd September 2017)
  18. #7900
    175 Post(s)
    Good job Marko.
    But what if one doesn't smoke ? Lol
    Also out of interest what were your symptoms for the leak ?
    Since my river crossings few weeks ago , my clutch and brake pedals go stiffer quicker ... Than before.
  19. The Following User Says Thank You to Hodge For This Useful Post:
