4th July 2016, 03:34 PM
Privacy curtains
I recall seeing a mention somewhere of detachable curtains or similar screens for the back side and rear windows for a wagon that were an off-the-shelf item.
I am unable to find any info now.
Anyone know about these?
4th July 2016 03:34 PM
4th July 2016, 03:37 PM
Check with @threedogs he was doing something similar I believe.
The Following User Says Thank You to Touses For This Useful Post:
Brissieboy (4th July 2016)
4th July 2016, 05:06 PM
Brissieboy
I had idea where I cut some black flexible perspex the same shape as the cargo area windows.
Seemed like a great idea as it would shield that area from any direct sunlight, they were held
in place via 5 x double sided suction cups.
The ones you're after are made from reflective silver material. from memory there is a thread
, where they have CAD drawings in PDF of the shape required. Then these are ones that go on
the outside to prevent rock strikes whilst towing. Maybe have a search and see what you come up with.
4th July 2016, 06:35 PM
OK thanks. Been searching but couldn't find anything.
I am looking for internal covers to save making curtains. And there is no easy way to fix curtains either - I was thinking suction cups with dowel top and bottom - not great but probably workable.
4th July 2016, 06:48 PM
The Following 2 Users Say Thank You to Stropp For This Useful Post:
Brissieboy (4th July 2016), MudRunnerTD (9th July 2016)
4th July 2016, 07:56 PM
Walk into officeworks buy some corriboard (you choose the color) for peanuts, cut to shape of inside windows, but slightly larger to overlap trims. Install on windows, and tuck edges under trims.
The Following User Says Thank You to Hodge For This Useful Post:
4th July 2016, 09:22 PM
Thanks Stropp - that is what I saw but couldn't remember where.
And never thought about the corriboard idea either, Hodge.
Will now re-look at the possibilities.
9th July 2016, 09:35 AM
#8
I got some insulation from Bunnings a while back, it looks like double sided reflective bubble wrap, similar to the stuff some of the windscreen sunshades are made of. Used duct tape on the cut edges to make it neater.
Graham
The Following User Says Thank You to GeeYou8 For This Useful Post:
Brissieboy (9th July 2016)
9th July 2016, 11:20 AM
#9
You may find if you make it tooo neat it wont breathe,,,,
as in the air in between gets hotter and the material will
billow out simple corri board would work with suction cups
Size you need is roughly 450mm x 350mm then start trimming to suit.
9th July 2016, 05:51 PM
#10
Patrol Guru
GeeYou8
Graham
I used the same stuff I reckon. It is garage door insulation. I got it on chuck out for $20 the roll.
The Following User Says Thank You to sooty_10 For This Useful Post:
MudRunnerTD (11th August 2016)
