Results 11 to 20 of 32
Thread: Blower fan propeller - No filter or grill?
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    BTW, just a thought crossed my mind, this dust circulating through the vents also pass through the A/C evaporator when the A/C is on, don't they? And that means, the evaporator eventually end up being gunked up with layers of dust? Which means, it might be a good idea to pull blower unit out to access the A/C evaporator and give it a clean?!!
    Any thoughts?
    ______________
    If you're a clean freak yes you can , I'd hate to think how bad mine is .
    Legendary dom14's Avatar
    38 Post(s)
    Nah, I meant is it possible for the evaporator to deteriorate, performance wise(thermal transfer wise) 'cos of the dust buildup on it over many many years?
    I'm just wondering.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  4. #13
    80 Post(s)
    This is the filter assembly I made to fit the top of the ducting above the fan.
    I made the filter out of the stainless mesh (top and bottom) for a leafeater and two layers of stainless flywire with a thin layer of fishtank filter sandwiched between them. It only takes one cable in the middle cut to replace the filter.
    After dropping the fan out (three screws and a connector) I dropped the ducting out and vacuumed the crap out of the cooling fins.
    I sprayed diluted disinfectant in and rinsed it out with water.
    There was a lot of black horrible crap dripping out the drain in the engine bay.
    I also took the opportunity to renew the seal around the top of the duct and the plenum chamber (body) with a few layers of self adhesive foam.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (12th April 2017)
  6. #14
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Only problem I've ever heard of is the electrical part of it , you lose speeds usually low goes first then medium etc .
  7. #15
    Aug 2010
    adelaide
    you could go to sca and purchace the aftermarket filter for it about $30.00
    have a read of this thread
    http://www.nissanpatrol.com.au/forum...t=cabin+filter
    OH LEATHER IS NICE
  8. #16
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I'm just wondering.
    Yes it does. Just like mud and grass caught in front of the radiator. It reduces it's ability to transfer heat.
  9. The Following User Says Thank You to Yendor For This Useful Post:
  10. #17
    38 Post(s)
    Thanx mate.
    It looks like bit of PITA job to perform by pulling out the under dash blower fan unit, but I think I'll get to it.
    Wish me luck,
    Cheetah Outreach
  11. #18
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Thanx mate.
    Wish me luck,
    There was a good thread on the other Patrol forum where they removed the blower fan housing and the bottom part of the evaporator box so they could clean it out and replace the seal between the two boxes. I think some even made up a filter/screen to go between the two boxes. I'll see if I can find it for you a bit later.
  12. The Following User Says Thank You to Yendor For This Useful Post:
  13. #19
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
  14. The Following User Says Thank You to Yendor For This Useful Post:
  15. #20
    38 Post(s)
    Thanx mate, it's very useful indeed.
    I'm going through it now.
    Cheetah Outreach
