Results 1 to 5 of 5
Thread: 2000patrol zd30 loss of power after 6 sec
    Mar 2018
    Hi everyone,
    My names gav,got a problem with zd30.direct injected. After 6sec of excelleration I loose all boost. I then take foot off and back on then boost returns. I have replaced every thing under bonnet. No engine light appears therefore no codes.please help .cheers.
    38 Post(s)
    I reckon it's going into limp mode.
    Define "Ive replaced everything"... does that include Boost Sensor, cleaned Maf Sensor etc?
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    JackCollo (9th March 2018)
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    Quote Originally Posted by Jacko71 View Post
    Hi everyone,
    Hey gav hope your well I can tell you exactly what this is mate. This will be your car going into limp mode like the evil twin said. Do you have a boost controller on the car. There is a boost sensor on the inter cooler this reads the boost within the intercooler and has a cutout boost of 16psi which sends the car into limp mode. Well more of a limiter the revs sit about 2000 rpm and no matter how much gas you give it no increase.
    Unless you have your boost set to a really high setting that’s the only thing I know to set the sensor off.
    My patrol did it when I got a Dawes kit for it but after fiddling around with the boost setting it was perfect never went off again
    Jack
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
    103 Post(s)
    If you still run the OE Intercooler and its oily its leaking, dont bother repairing it buy a fully
    tig welded on from say Diesel Smart, they are 33% bigger as well then you need to know whats
    happening under the bonnet like boost and egts usually in a pillar pod or dash pod. Have a read up on NADS
    a must for any ZD30
    Dec 2016
    a must for any ZD30
    No better words spoken from anyone TD mate
  8. The Following User Says Thank You to JackCollo For This Useful Post:
    threedogs (10th March 2018)
