Page 1470 of 1651 FirstFirst ... 47097013701420146014681469147014711472148015201570 ... LastLast
Results 14,691 to 14,700 of 16505
  1. #14691
    May 2016
    lower west victoria
    30 Post(s)
    So much quicker and easier on the old body
    Yep, they're bloody great aren't they. I love chopping wood, but it's harder than it used to be these days. We split 5M of redgum last weekend with a ram splitter. Better in every way.
  2. The Following User Says Thank You to 10G For This Useful Post:
    NissanGQ4.2 (16th August 2020)
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Bitter_Sweet. At least we still have electricity (Uninterrupted Pwr Supply).
    Was woken up to this crashing down this morn 0530hrs.
    Bit of sorting out to be done today (busy). Hope all is OK with batteries inside, issue will be getting it off roof and see what is going on.
    Gen (red unit) looks OK. Just missed water tank.
  5. The Following 6 Users Say Thank You to Bidja For This Useful Post:
    10G (20th August 2020), Cremulator (21st August 2020), Cuppa (20th August 2020), MB (20th August 2020), mudski (20th August 2020), Plasnart (20th August 2020)
  6. #14693
    Ballarat, Vic
    174 Post(s)
    Good luck with that Bidja. Had similar in the past, but it was a hay barn mine took out. Needed a 4wd cherry picker to cut it out. At least I had no solar battery set up to worry about.
  7. The Following User Says Thank You to Cuppa For This Useful Post:
    Bidja (20th August 2020)
  8. #14694
    49 Post(s)
    Picked up my welder today.
    Had a quick little play with it and pretty happy so far. Found an old trolley at work and grabbed some scrap. 1st pic is first attempt 4mm, happy that with a descent hammer not of it come apart, that's gasless. Will have to set up the wire tension/speed correctly, but with some more practice it will do me fine.
    Also got my meat to make beef jerky over the weekend .
  9. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (20th August 2020), Mickhead (21st August 2020)
  10. #14695
    193 Post(s)
    Looks really good. I am still struggling to get my Rossi 130amp unit to lay a decent bead. Understanding that all welders are different, could you tell me the speed and power/voltage settings you are using? This might put me onto a quicker success path. I have done the internal reconfiguration to run on gas now, but looking at your gasless results I might just swing it back for a trial.
  11. The Following User Says Thank You to PeeBee For This Useful Post:
    jay see (20th August 2020)
  12. #14696
    461 Post(s)
    Looks really good. I am still struggling to get my Rossi 130amp unit to lay a decent bead. Understanding that all welders are different...
    Might be the person operating the welder. Lol
    @jaysee you should find that using gas will stop the spatter you have around your welds. From what I was told anyhow. The gas is there to form a shield around the weld to hold the heat in for a cleaner weld. So I was told again.... I've never tried gasless on my mig.
  13. The Following 3 Users Say Thank You to mudski For This Useful Post:
    Avo (20th August 2020), jay see (20th August 2020), PeeBee (20th August 2020)
  14. #14697
    193 Post(s)
    You are right, but I guess if YOu can use a HIG then its got to be the settings.
  15. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
  16. #14698
    49 Post(s)
    Settings are 80 amp and 3 on the wire speed.
    Your right on the spatter Mark gas is cleaner. I'll grab some anti spatter from work next week and try that.
  17. #14699
    581 Post(s)
    Got to use the Patrol today!
    MB called me this morning with a lady who had slid off the road at the bottom of my street into a ditch so had to pull her out.
    Highlight of my Covid ISO week
  18. The Following 9 Users Say Thank You to AB For This Useful Post:
    Avo (20th August 2020), Bidja (20th August 2020), Cremulator (21st August 2020), jay see (20th August 2020), MB (20th August 2020), mudnut (20th August 2020), mudski (20th August 2020), Plasnart (20th August 2020), Yeti's Beast (28th September 2020)
  19. #14700
    461 Post(s)
    Yep. Practice makes perfect they say. My welds usually resemble chicken poo, but to my surprise my last attempt on the ARB bar, thankfully came out pretty good. I think I just lucked it with the right amp setting, wire speed and gas. I bet the next time they wont be so neat.
  20. The Following 3 Users Say Thank You to mudski For This Useful Post:
    jay see (20th August 2020), Mickhead (21st August 2020), PeeBee (20th August 2020)
