Page 864 of 1049 FirstFirst ... 364764814854862863864865866874914964 ... LastLast
Results 8,631 to 8,640 of 10488
  1. #8631
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Started modification to my JT cooler frame. Want to fit some rubber isolators between frame and cooler to hopefully dampen some of the resonance (noise) caused by the induction air passing thru the tube and fin core (turbulence) @ 26psi boost.
    Removed cooler, started by modifying frame to lift cooler to provide more clearance between frame and cooler.
    Also needed to increase the distance between the frame mounting lugs ( ie 30mm each, Fwd & Aft) so to fit 30mm dia x 30mm length rubbers isolators for mounting cooler to frame.
    Put the rubber isolators onto original lugs so to determine brkt mod profiles and placement, made the new mounting lugs up out of some RHS laying around, jigged them up in place ready for welding tomorrow and then will cut away original lug excess. Coming together and figuring out as I go. So far good.
  2. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    GQtdauto (12th October 2018), MB (12th October 2018)
    Nov 2010
    Getting a life...
    38 Post(s)
    I had to laugh, I saw a thumbnail of this pic in Tappa on my phone and I instantly knew where this pic was taken and I haven’t been there, or to that shop for probably 10 years I reckon.
    Sent from my crapPhone using Tapatalk
    And it probably hasn’t changed a bit
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  5. The Following User Says Thank You to katwoman For This Useful Post:
    mudski (14th October 2018)
  6. #8633
    461 Post(s)
    Took the Patrols pants off.
    Getting ready to put the Milweld bar on.
  7. The Following 4 Users Say Thank You to mudski For This Useful Post:
    Bidja (14th October 2018), Hodge (14th October 2018), MB (15th October 2018), PeeBee (14th October 2018)
  8. #8634
    Jul 2017
    37 Post(s)
    Completed mod to JT frame and installed (frame & cooler) back in veh. All went well and the resonance noise has completely gone.
    Ended up lifting cooler relative to frame by 5mm, increased the clearance of rail under hot tank inlet to suit lift plus need to fit joiner. Used the 4 x Mackay Multicusion rubber isolators (M10303055) between frame and cooler and made up some rubber pads to fit between frame and veh body.
    Even the boost went up one psi, have brought it back to 26psi running well.
  9. The Following 4 Users Say Thank You to Bidja For This Useful Post:
    GQtdauto (14th October 2018), MB (15th October 2018), mudski (14th October 2018), PeeBee (14th October 2018)
  10. #8635
    461 Post(s)
    I so need to do this to mine. 30+ psi of boost under full load and bloody noisy as hell in mine.
  11. #8636
    Jul 2017
    37 Post(s)
    What cooler do you have?
  12. #8637
    461 Post(s)
    Cross Country ultimate cooler. Pretty much the same as yours. Except the bracket looks different.
  13. #8638
    175 Post(s)
    Yep. Mine is the same. Cross country .
    Under full boost I feel like I'm at the tulla airport plane lookout ...
    Jul 2017
    37 Post(s)
    Yes CC & JT coolers they are very much the same build. JT does different inlet (hot side), for CRD only use the OEM 45 deg elbow to make the 90 deg bend hook up to turbo. JT cooler assy with fan no frame is 8.85kg.
    Mine was terrible under load and boost above 20psi. As Hodge said like a jet plane.
    TD42 and CRD frame may differ (not sure) but I had mine modified to accommodate 3" induction pipework. You need at least 5mm clearance between frame and cooler to allow for movement with the rubber isolators.
    Can discuss mod further if suits. Has made such a difference it was hell on the hwy hauling.
  15. The Following User Says Thank You to Bidja For This Useful Post:
    mudski (15th October 2018)
  16. #8640
    581 Post(s)
    Just drove in from an awesome 3 days on my own around Woodspoint!
    Explored, prospect and hiked around finding some old miners settlements and old boilers, etc. one of the best trips I've done.
    Nearly stood on a snake in the middle of nowhere hiking along one of the tracks.
    Lockers saved me at one point heading down a seldom used track to explore an old mining spot.
    Kind of scary on your own as the track got steeper and steeper with no way to turn around so fully committed and just enough room for a 10 point turn.
    Would've been winching for hours without lockers. Photos doesn't do much.
  17. The Following 16 Users Say Thank You to AB For This Useful Post:
    Avo (15th October 2018), Bidja (15th October 2018), Clunk (15th October 2018), gaddy (15th October 2018), GQtdauto (15th October 2018), Hodge (15th October 2018), jay see (22nd October 2018), MB (15th October 2018), mudnut (15th October 2018), mudski (15th October 2018), neet_wagon (15th October 2018), PeeBee (15th October 2018), Plasnart (15th October 2018), Rossco (15th October 2018), rusty_nail (16th October 2018), Stropp (23rd October 2018)
