29th May 2017, 01:41 PM
What size bolt?
Weird question, but I seem to be missing the bolts that go where the baby seats are meant to clip in. It's a 93 GQ LWB RB30.
Anyone know what size bolt/thread it's supposed to be? She's going swimming soon and I'd rather not have a fountain coming in through the back.
29th May 2017 01:41 PM
29th May 2017, 11:11 PM
30th May 2017, 07:43 AM
any place that sells baby seats will have the bolt as an extra or just put a bung in it ar cork of tape
OH LEATHER IS NICE
30th May 2017, 11:28 AM
I just use a bit of sikaflex to seal the hole. I leave a few threads clean so I can just screw in the bolt if the anchor points need to be used. After the deep river crossings a few years ago, when I had to lift the carpet, I found a more holes than I could poke a stick at. I spent a long time sealing them and the edges of all the plastic screw inserts.
I even glued some rubber discs over the holes in the top of the sill panels and up the pillars. I also used some small food containers as junction boxes to seal off the loom plugs under the front passenger seat and also the wiring and relays used on the air compressor under the rear passenger seat.
30th May 2017, 11:40 AM
IT should be either 10mm v 1.25 pitch or 12mm x 1.25 pitch, you can determine the length
30th May 2017, 12:31 PM
dom14
Sounds like you've been busy mate.
No, I don't have a clue about the baby seats(I've never been a baby
I'm sure few blokes with toddlers or who used to have babies before they outgrew them know the exact answer.
P.S. I'm sure baby's thriving at super fast growth phase and walking around the house by now.
Yeah mate, always something going on in this crazy life! Yeah, the young fella is growing too quick! Almost walking.. Time flies!
The Following User Says Thank You to Throbbinhood For This Useful Post:
30th May 2017, 12:32 PM
my third 256
Good thinking cheers mate
30th May 2017, 12:33 PM
mudnut
Yeah I was thinking that, but figure I need the bolt anyway if I decide to move the seat or when number two comes along. I like your thoughts on the wiring/food containers etc. She's normally fairly water tight, at least for what I've done in her, but saw the bolt missing so figured I'd sort it out.
30th May 2017, 12:34 PM
threedogs
Absolute gun mate, thankyou!
30th May 2017, 12:38 PM
Mines a GU, but I needed some longer bolts in the back, including the baby seat anchors. I can't remember the size but after visiting a nut/bolt supplier, he found a strange mix of metric fine thread and UNF (American fine thread). Not sure what Mr Nissan was thinking?
Andrew
GU3 Patrol, TB48, 33" muddies. front E-locker. 4.11 diff gears. 2.2 metre steel rack. Awning. Steel rear bar. Safari Snorkel. ARB side steps and brush rails. ARB Deluxe bull bar. Winch. 2" lift.
