20th July 2021, 04:02 AM
Motor rattle 👎
Hi guys I have a dilemma, when I was at my daughters wedding at Jindabyne I drove there fine, the next morning when I went to start the car it hesitated and ran on 5 before picking up the other cylinder but it was quite rattly however it quietened down but there is a rattle when it’s cold still and gets quieter when warm, it also blows a bit more diesel smoke than before? I’ve had the injectors checked and according to Matt at pro diesel they are ok and he says next step is pull the motor as he is stumped, which is not what I wanted to hear. Any ideas before I decide what to do Anyone?? Cheers Stropp
20th July 2021 04:02 AM
20th July 2021, 09:18 AM
Could it have been a very cold morning where a bit of extra glow time might have helped? It's happened to me a couple of times where it blows the unburnt diesel out and runs like a pig for a few seconds.
John
20th July 2021, 09:49 AM
A bit cold up the snowies this time of the year.
Remove your glow plugs and test with multimeter (check ohms from connector terminal across to probe).
One most likely no good.
20th July 2021, 10:43 AM
yep sounds like one glow plug is not playing well with others .
I am in Canberra and spend a bit of time in the snow mine is a bit noisier when its below 0 . until it warms up the pump runs advanced until it warms up .
I put a bit of cardboard in front of the radiator. And yes they sound bad at -7 C
The Following User Says Thank You to Tip12345 For This Useful Post:
20th July 2021, 01:34 PM
Yeah mines rattly when its cold. fine when it warms up, eventually.
20th July 2021, 02:18 PM
Tip12345
I do not have to go above 1200m to go below -7, just step out my back door(only have 1) and can crunch the tussock.
We do not live far from each other. Was in CBR this morn.
The Following User Says Thank You to Bidja For This Useful Post:
20th July 2021, 02:57 PM
Do you have Alpine diesel in the tank? If not you could have a problem with the fuel waxing up.
20th July 2021, 05:46 PM
#8
Is yours a 12mm pump Stropp think it's just a12mm thing when cold. . Mine blows smoke and misses when cold to much fuel to burn properly when it's cold with no boost to match. .
The Following User Says Thank You to Rossco For This Useful Post:
20th July 2021, 05:47 PM
#9
BillsGU
Ok, this happened some time back and I had filled up in Wagga at apco cheap diesel,I put it down to that exact problem with waxing however it still makes a bit of a rattle and blows a bit a smoke which it never did before, could possibly be the 12mm boost compensated pump may not have liked it and that could be the source of the rattle ?
20th July 2021, 05:50 PM
#10
Rossco
Thanks rossco I hope that’s what it is, I may just leave it for now and hopefully get up for you guys to have a listen and see, the original owner said it maybe the problem too and it was tuned in a warmer climate!
