Results 11 to 20 of 21
Thread: easy way to get tdc on td42
    Expert Col.T's Avatar
    Nov 2010
    Seaview Dwns.S.A.
    G'day again Mac,
    I read these posts in the wrong order but you're on a few winners here aren't you?
    TDC is in principle, easy to find, at least using my dear departed daddy's method and I used it for about 15 years on my TD42. PROVIDED you have a manual.
    Put it in top gear, hang onto the bull bar and give it a pull forward. Keep bouncing it as hard as you can and belt tension will crank it slowly over until you reach TDC..May cost a rooted back or something but that's what real men do. I think.
    Difficulty is in seeing the tiny mark on the wheel/pulley. It's beautifully placed by Mr. Nissan behind guards/covers/bullshit etc. but with a torch you'll get it. With luck. Once you have, slap some white paint or whiteout on it as I did on my first FC Holden recently. About '57.. Means it's easy to see for the rest of your life.
    Got an auto? Dunno what but if I suggest the same, never having owned an auto, I'll happily stand corrected. As for the rest, sorry mate, I'm lost.
    Good luck again,
    Col
    Mar 2015
    Quote Originally Posted by Col.T View Post
    G'day again Mac,
    Good luck again,
    Col
    thanks col yeah my old man did it the same way lol but my drive has a downward slope so not a good idea here lol
    I never go into the outback with out a decent supply of water,
    and the general rule for how much you'll need is three litres
    per day , per person, per man per degree over 25 degrees
    celcius, per kilometer if walking on foot, in the winter months
    dividing it by two, plus... another litre... at the end .... Russell Coight
  4. #13
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    I always found the easiest way was to remove the Glow Plug from N#1
    scrunch up a tissue, and plug that in the Glow Plug hole
    wind over - by hand - the Crank or the Power Steering pulleys
    when the tissue pops out, your at TDC
  5. The Following User Says Thank You to Bigcol For This Useful Post:
    Col.T (13th June 2016)
  6. #14
    Mar 2015
    thats how i ended up doing it BC
  7. #15
    Patrol Guru firm351's Avatar
    Jun 2013
    Mundijong, WA
    4 Post(s)
    Quote Originally Posted by Makka View Post
    i think i did it wrong it seams it is noisier ....... anyone on the central coast nsw wanna come over and give me some help ??????????
    i got cans of wild turkey lol
    how did you end up doing it mate. Just wondering so we can see if you did it right or wrong.
    What valve clearance did you set?
    Are you sure you were on TDC on the compression stroke and not on the overlap?
  8. The Following User Says Thank You to firm351 For This Useful Post:
  9. #16
    Jun 2013
    Mundijong, WA
    4 Post(s)
    Quote Originally Posted by firm351 View Post
    Never mind, you answered my question while I was asking it.
  10. #17
    Mar 2015
    it all pretty much works on the same principal as a petrol motor. so it is all coming easier just needed to make sure i was correct and it all turned out right but there are other issues que sera sera
  11. #18
    Nov 2010
    Seaview Dwns.S.A.
    G'day Firmboy,
    can't remember when that applied to me last.....Oh well.
    Seem to vaguely remember that when you had TDC you were either ready to set clearances on one set of 6 valves or the other. Not sure now but I think if they were supposed to be open but weren't, I just reset the other six.
    Jeez, I hate computers and turbos. Those were the days,
    regards,
    Col.
  12. #19
    Mar 2015
    G'day Firmboy,
    regards,
    Col.
    thats correct col tdc on 1 was 1 3 5 10 11 12 i think and then tdc on 6 was 2 4 6 7 8 9 i think i have not got the piece of paper in front of me ........
  13. #20
    The td valve sequence is different to the tb sequence. I hope your bit of paper says different to what you wrote here.
    Td42 on #1 tdc- 1,2,4,5,8 and 9
    #6 tdc- 3,6,7,10,11 and 12
