Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 68
Thread: Harrop Eaton ELocker Versus GU Family Wagon Auto Hubs
  1. #41
    192 Post(s)
    I'm happy when the 43's but think I would be equally happy with the 63's. If your after a little bit more the 43's will do the job fine, 63's will really crawl if that's what your into. Reckon you'd be happy with 43s. .
  2. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    Bidja (28th November 2020), MB (29th November 2020)
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Thanks Rossco, appreciate your comments mate.
    Just have to work out the locker type_ARB air locker does appeal. Did see the US made OX locker (mechanical engagement, do like their use of a cable and in-cab lever for engagement (thinking though not available for Nissan Patrol). Have sent them an email will see what they say.
    Edit: Have just received email back from OX Locker (OX_USA) and advise that:
    "We do not make one for the Nissan’s at all".
    Pitty that_will move on deciding.
    Last edited by Bidja; 29th November 2020 at 07:50 AM. Reason: Update OX_USA do not make locker for Nissan's
  5. The Following User Says Thank You to Bidja For This Useful Post:
  6. #43
    80 Post(s)
    While you're deciding, could someone please explain which ARB seals fail and allow diff fumes to enter the cabin? And is there a an easy fix, or have they dealt with that issue?
  7. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    Bidja (29th November 2020), MB (29th November 2020)
  8. #44
    472 Post(s)
    The only way I could imagine diff fumes ‘constantly’ entering the cabin Muddy Mate would be through a jammed open locker solenoid if they’re installed in doors. I prefer them safely inside anyway and will always get the slightest wiff selecting on/off/on around hairpin climbing hills. One could always take the solenoid exhaust diffusers out and pipe exhaust them outside too whilst maintaining all the good bits solenoid/compressor safely indoors. To be honest hasn’t bothered me yet, most times when the lockers are on I have my head half out the window choosing rock lines slowly crawling and the Chev’s diesel incoming exhaust window fumes are much more of a problem
  9. The Following 2 Users Say Thank You to MB For This Useful Post:
    mudnut (30th November 2020), Rossco (29th November 2020)
  10. #45
    201 Post(s)
    Yes my solenoids are in the cab and when ARB installed it they vented them outside.
  11. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (29th November 2020), mudnut (30th November 2020)
  12. #46
    472 Post(s)
    Another peace of mind factor keeping all the good bits safely indoors is the audible tell tales that everything is working as it should under extreme much needed circumstances.
    An example of this is if your compressor is kicking in too often you’ve sprung a slight leak somewhere out there. If your compressor is running full time then you’ve accidentally ripped a line clean off.
    The solenoid/s (plural for twin lockers) have a very distinct sound when they’re exhausting properly or not.
    Prior to installing a moisture remover/capture thingy in my main air system line prior to the 20L under tray air tank I was getting locker solenoids freezing shut on snow trips, well worth installing a good one of them for sure
  13. The Following 3 Users Say Thank You to MB For This Useful Post:
    Bidja (29th November 2020), mudnut (30th November 2020), Rossco (29th November 2020)
  14. #47
    472 Post(s)
    Decided to give Grandpa Spec his first shot of Viagra tomorrow....look out Ladies
  15. The Following 4 Users Say Thank You to MB For This Useful Post:
    Bidja (2nd December 2020), Mickhead (3rd December 2020), Rossco (2nd December 2020), Winnie (2nd December 2020)
  16. #48
    201 Post(s)
    You are an absolute mad bastard MB!
  17. The Following 3 Users Say Thank You to Winnie For This Useful Post:
    10G (8th February 2021), MB (2nd December 2020), Rossco (2nd December 2020)
  18. #49
    192 Post(s)
    Bloodey el Markie, no stopp'n ya
  19. The Following User Says Thank You to Rossco For This Useful Post:
    MB (3rd December 2020)
  20. #50
    193 Post(s)
    You installing @MB - need my tap for the diff fitting? Watch out for the location, sure you won't get caught twice?. Sing out if you need it. Is this for front or rear?
  21. The Following User Says Thank You to PeeBee For This Useful Post:
