Page 29 of 54 FirstFirst ... 19272829303139 ... LastLast
Results 281 to 290 of 536
Thread: Harrop 2300 supercharger to Optimiser 6500
  1. #281
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Nah Philbus we’ve been full on - we’re deemed an ‘essential service’ so kept working - after the last 6mths I ain’t complaining . Our biggest threat is the greenies stopping us . Anyway as for this ‘self isolation’ - I’ve been doing that for nearly 25 yrs so I’m all over it haha
  2. The Following 3 Users Say Thank You to Sprock For This Useful Post:
    MB (3rd May 2020), PeeBee (3rd May 2020), Rossco (3rd May 2020)
    194 Post(s)
    Hoses and fittings arrived for the air compressor installation under the middle row seats, so finished that off, happy with the result Installed so rubber stone guards around some cables under the front wheel arch. Have a squeaking sound coming from somewhere around the powersteering pump, found it has running a lowish fluid level, topped it up but made no difference. Sound goes away after say 5 minutes of idle, looking but cannot identify the source.
    Now just waiting for the w2a big pump - its arrived in NSW, so with luck will have it early next week. Then the tank can be made and fitted up.
  5. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (6th May 2020), MudRunnerTD (6th May 2020)
  6. #283
    330 Post(s)
    Give it a crack!!!
    #nekminit #justsendit
  7. #284
    194 Post(s)
    Speechless! Wonder what the rest of the motor looks like, and guessing a little bit more boost than I am running!!!
  8. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MudRunnerTD (11th May 2020), Plasnart (11th May 2020)
  9. #285
    194 Post(s)
    New EMP WP32 pump arrived today, finally at 5pm, so that's a win for tomorrow. The 10L tank is fabricated and I just need to cut and weld the inlet and outlets into it. I think by the time I make the pump mount bracket and mount that off the tank, run the cables to relay and isolator etc, 2 days will be done and dusted.
    Added a touch sensitive light to the rear cargo barrier timber board so interior is well lit up. Still have that damn ticking sound on start up - cant find the source, will drive me spare until I know what it is and fix it though! Will post photos later tonight.EMP Pump 1.JPGEMP Pump 2.JPG
  10. #286
    194 Post(s)
    Another good day in the garage. Finished off the tank, mounted the pump and painted the tank ready for a coat of epoxy bitumen then thermal insulation. Ordered some custom a/c fittings as the clearance off the firewall is very tight. With luck will have them by Monday. Replacement Couplertec unit arrived and fitted that up also.
  11. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    mudnut (13th May 2020), poindexter (13th May 2020)
  12. #287
    194 Post(s)
    Bit of stuffing around, waiting on the custom a/c fittings.Triple insulated pump.JPGTank drying.JPGbitumen paint.JPG
    Triple insulated the pump and motor assy, trying to get the tank to dry in Melb's 13 degC day is a challenge
    MudRunnerTD (13th May 2020)
  14. #288
    330 Post(s)
    You missed your calling Phil! you have a Knack for Painting for sure mate!!
  15. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    PeeBee (13th May 2020), Rossco (13th May 2020)
  16. #289
    194 Post(s)
    Darren, we are all good at some stuff and not so good at others!!! House painting is fine, handling this 2 pack bitumen paint is another thing all together. Its too cold to be applying it to be honest, plus, normal heat activation to accelerate the hardener does not work - it makes the mix more plastic, so I ended up setting up the fan with coldish air all day - and it still looks like crap,. Anyway, tomorrow I do the plumbers thing and cover it under a couple of layers of insulation, so the scar will be hidden - but thanks for highlighting my failings!- mate.
  17. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MudRunnerTD (14th May 2020), Winnie (14th May 2020)
  18. #290
    194 Post(s)
    Here you go Darren, all hidden and looking beautifoooooltank 1.JPGtank 2.JPGtank 3.JPGtank 4.JPG
  19. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
