Results 1 to 5 of 5
Thread: patrol turbo waste gate noise
    May 2019
    hi thanks for letting me be part of your group i have problem with 2011 3.0 turbo auto patrol turbo there is a flaping noise near or in turbo until you tack off wastegate vac hose thats if this model hase the waste gate turbo anyone had this problem
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Quote Originally Posted by mjdboys View Post
    The ZD30 CRD engine is fitted with a GT2052V Garrett VNT turbo. The VNT is "varable nozzle (Geometry) turbo" meaning that it has adjustable vanes that control the amount of exhaust gas pressure/flow to enter the turbo housing to rotate the exhaust wheel / turbine to achieve and control boost.
    Try and help here mate. We need a bit info on flap noise:
    Metallic or hose like flap (describe it a bit more)?
    If it is a metallic sound is it like a fan hitting metal cowl/shroud?
    Only at idle (low boost)?
    When you remove vac hose off actuator what does the actuator rod do?
    When noise is heard, what is the actuator rod doing and at what is it's position with vac hose connected to VNT actuator?
    Have you got manual boost control (Tillix or Dawes with needle valve)?
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day mate and welcome to the forum.
    Advanced thebrod's Avatar
    Sep 2013
    I had a noise in my 3.0 turbo that was sounding a bit like a blow off valve when backing off (we don't have one of those either!).
    Ended up being a crack in between the flange and the dump pipe on the turbo exhaust.... Didn't make any excessive noise while driving - just when backing off the accelerator.
