Results 1 to 10 of 14
Thread: Dawes adjustment
    Dawes adjustment
    Hi all need the correct answer as have two different ones so far, DAWES fitted to my truck. Now how do you REDUCE the boost????? Screw it IN or OUT. amd yes I've been through the ARCHIVES
    Unafordable
    4 Post(s)
    Screw it out (by doing so the spring tension is reduced so less boost pressure is needed to overcome it.)
  4. The Following User Says Thank You to Rumcajs For This Useful Post:
    threedogs (10th July 2012)
    Perth WA
    In increases spring pressure on ball that boost pressure has to overcome, so
    IN=MORE BOOST
    2004 GU ST 3.0 DDi 2" Tuff Dog Lift, Warn 9000lb, Custom dual Batteries Redarc, Safari Chip + Snorkel, 3" exhaust, NADS, MBC, DIY can, PWR Int,+9" fan, 7" GPS-DVD-TV Igo8 and Ozi with 2cams,6.5" Kicker splits and 6x9", Pillar+ Racetech EGT-PSI, Heated seats, fixed compressor, Arduino dual battery and engine/OAT temp display, 3" Projected 50W HID's with halo DRL's........so far.
  6. The Following User Says Thank You to adventurepaul For This Useful Post:
  7. #4
    Thanks can put this one to rest, now, I'm nearly all the way out, but the spring was stretched a little. hopefully now it will be sorted today
  8. #5
    Right adjusted it all the way out, but thought boost was still a bit high. Pulled DAWES apart and compressed spring by twisting gently. hopefully this time, I hear a bearing kind of noise after I turn it off hoping this is normal turbo noise winding down. And all because the alternator was changed. oh well. once I get boost right I'll fit system supplied by Diesel smart. I still have hope
  9. #6
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    what boost are you trying to run. I found my Dawes wouldn't go high enough. Could only get 10PSI at max compression. even stretched the spring a little to get 11.. still yet to get back to it to make it any higher.
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
  10. #7
    When first fitted the vac lines were wrong so spring was stretched to up the boost. now vac lines are 100% and boost was going through the roof and truck was going into over boost. Compressed the spring by twisting and MAX is now 15ps and not going into overboost. Would like to see it a tad lower maybe 13psi. EGTs are great 220 DEG C cruising with boost on 10 psi. EGTs rise as normal when pushed. Dont know if I need to fit the needle valve as well, it's running that well. more updates later as I'm trying a module from DIESEL SMART as well my DP Chip.
  11. #8
    Quote Originally Posted by scotty83 View Post
    Yeah! I've only got mine barely 3/4's in and I'm nudging 16psi at full noise.
    Hey TD, best to start a new thread I reckon on your findings of this diesel smart thingo you got.
  12. The Following User Says Thank You to mudski For This Useful Post:
    DieselSmart (13th July 2012)
  13. #9
    Shall do, Trucks flying at the moment, was instructed today via email to increase boost. It now peaks a tad over 15 psi. still doing fuel run so I'll try to get some Ks happening.
  14. #10
    His got our AFM DSI which plugs into his AFM to allow him to run more then 16PSI without it hitting boost cut. This also prevents his car from hand grenading as the motor will never be able to go into boost cut. Will be interesting to see the results of his extra power and better fuel economy over a few hundred KM's.
